My ac unit does not produce enough hot air even when on high
It's low on freone
Posted on Dec 31, 2008
How do you run ac units with generator
You have to be sure the generator produces not only enough power to run the AC but also to handle the load when the AC initially starts or the compressor kicks on. That means it either must have a continual wattage rating to handle the load or a surge rating that's powerful and long enough to handle the start up.
Aug 21, 2014 | Heating & Cooling
My AC control switch went out, I replaced it with a used one and it worked for approx 30 min. (the lights went out on it) but it still controls the blower (hot air) from OFF to HIGH. I replaced it with a...
Sounds like a connector has a bad terminal or socket. It has high resistance and gets hot enough to melt things in a short time.
AC Delco makes the contacts out of plated steel. Sometimes in the AC system, some condensation collects and rusts the contacts in the connector, causing high resistance and over heating.
Good Luck
Sep 22, 2017 | 1998 Chevrolet Suburban
Why does a 2008 dodge ram 5500 CUMMINS automatic Transmition get hot when i use my ac when the weather is hot outside
Its possible the radiator is not cooling enough to handle the engine and trans. Depending on where the aux cooler is for the trans, there may not be enough air flow thru the radiator. With the condenser in front of the radiator the ac produces extra heat the radiator has to overcome.
Aug 16, 2012 | Dodge Cars & Trucks
Check charge and it shows proper pressures and still blowing hot air
ARE WE LOOKIG AT A CAR OR HOME UNIT
HOME UNIT AC COMPASADOR KILL POWER TO AC MOUNTED ON SIDE OF INSIDE UNIT SMALL CAN WITH 4 WIRES TOP OF CAN WILL SHOW SIGHNS OF BOWING OUT,THEY WILL BE # LIKE
5 - 30 MAKE SHURE YOU MATCH # UP WEA RUBBER GLOVES
EVEN POWER IS OF THE WILL BE ENOUGH POWER TO GIVE YOU A GREAT JOLT KEEP AN EYE WHAT WIRES GOES WHEAR COMPRESSOR FAN WILL START AGAIN THE UNIT HAS 2 FANS ONE TO KEEP CONDINSOR COOL AND OTHER TO KEEP COMPRESSOR RUNING GOOD LUCK PART $90
Jul 07, 2012 | Heating & Cooling
I had my a/c charged today because it has not been cooling the house down. It took less than a pound, but it still blows worm air. Fan and compressor all running. I cleaned outside unit, filters, replaced...
It could be that it is not charged correctly. Check the insulated copper
line outside if it is sweating and the condensor is discharging hot air, then the ac is doing all that it can. Check the evaporator inside to see
if the drain has condensate coming out of it.
Getting the heat out of the attic is a good idea, but you must have enough make-up air in the attic for the fan. If you do not have enough
make up air, it will start to draw air from inside the house. One way to check this is if you have a gas water heater and or furnace. If you put
a flame by the exhaust pipe in the basement and it blows it out, then you now have a backdraft problem.
Run the AC withoutthe fan, my real guess is the unit is not properly
charged or you do not have a big enough AC unit.
Jul 17, 2010 | Goodman CKL36AR36 Air Conditioner
Air not cold enough to cool house
Make sure the outside fan is running. Also check the high side pressure, I assume the 70# is the low side pressure, so you can tell what the compressor is doing. If the fan and compressor are both working, make sure there is good airflow through outdoor coil and check that it is clean. Let me know what you find.
May 17, 2010 | Goodman CLJ24AR32 Air Conditioner
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
A/c blows hot
Your car is low on refrigerant.
  1. Your system requires R-134A refrigerant which is available at most auto parts stores.
  2. You will also need a hose to connect the refrigerant to the AC system.
  3. You will need to locate the low side AC fitting (looks like a nipple)
  4. With the car running and the AC turned on high, attach the hose to the AC fitting,
  5. attach a can of refrigerant to the other end of the hose.
  6. Turn the screw on the hose to puncture the top of the refrigerant.
  7. Move the can back and forth until the refrigerant is empty.
  8. Detach the hose from the AC system.
Check to see if frost forms on the AC lines under the hood and cool air blowing from the vents inside. If the air isn't cold enough, add another can of refrigerant.
CAUTION: Do not overfill the system. If the system doesn't "**** in" the refrigerant, the compressor needs resetting (disconnect battery 5 min in GM cars and trucks)
I hope this solves your AC issue. All the best!
Greg
May 14, 2009 | 1997 Buick Park Avenue
Heating & Cooling Logo
142 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
