Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Top drawer stuck, gaskets rubbing, no power to controls
We realized our F&P top drawer stopped working this evening at the beginning of a wash cycle. The drawer appeared to have lost power, and would not open. I was finally able to pull steadily to get it open, but it felt obstructed by something above, though there is nothing but the rubbing of the rubber gaskets. Manual says there is a seal that inflates and deflates to lock, so I'm assuming it isn't deflating. The top drawer control panel is completely unresponsive.
We have already tried cutting power to the dishwasher and turning back on with no luck. The bottom drawer appears to be fine, has power, etc. Any ideas?
  • 2 more comments
  • ljacobs365 Jan 02, 2009
    my top drawer opens, but with great difficulty. the wash cycle still works.
    my model is dd 6031
  • calaha Jan 03, 2009
    Hi there - thanks for the tip, I didn't realize the posting area was so well organized. :) It is a DD603. If this is the case, any idea on what we should do?
    Should I be able to feel anything along the top of the washer that resembles a motor? It feels flat, like nothing but panel and gaskets.
  • Anonymous Feb 17, 2009
    I have a 603 also with the same problem. The door was stuck after a wash and then no power. Now what?
  • Anonymous May 17, 2009
    I have the same issue. Did anyone get theirs resolved. mine is a 603.
  • 145 Answers
I see the question is posted in the DD603 section, so I am not sure if I am giving the proper advice. Are you sure this is a 602/601 series? A DD603 model has lid actuator motors, not the inflatable style seal. It sounds like the lid motors are in the DOWN position. Since the machine is "dead" what may have happened is the heater plate opened up (the heater plate is a dropping resistor inline with the machine's controller) when the machine was in use and that stopped everything dead.
Double-check your model number so we know what style of lid your machine has, The difference is huge between models.
Posted on Dec 31, 2008
Wash started cycle. Wife stopped it at beginning of cycle. Now washer will not start at at. Lid switch is good. Will not spin, rinse, restart wash, nothing, not even clicking.
Does unit have a reset button? If it has manual control for cycle did you try going clockwise to the start position and then restarting?
If she stopped the cycle by opening the door perhaps that switch is still stuck in an open position.
Aug 31, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
How do i repair fisher paykel dd603 problem top drawer stuck on fast cycle, bottom drawe stuck on normal cycle
you will need to replace both draws control boards, with the dd603 control boards they have a small touch button panel on the top of the board which they didn't put a protective layer or plastic over and basically what happens is steam gets on the copper tracking and corrodes it hence the fact it doesn't work anymore, all new control boards even the replacement for yours comes with a plastic strip over the board. hope this helped
Oct 06, 2014 | Fisher and Paykel Dishwashers
Maytag is clicking when its going to weigh clothes and spin at the end of cycle
It's a faulty relay on the control board. If you remove the top panel and remove the boards you will find a spot burned out on one of the relays. If you know how to solder then you might be able to repair it.
Mar 04, 2014 | Maytag Bravos MTW6600T Top Load Washer
Top drawer can not be open
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
FISHER PAYKEL DISHWASHER DD603 Parts
Feb 10, 2014 | Fisher and Paykel Dishwashers
My control panel in the top dishwasher is not working. It will run but I can't change the cycle and it is stuck on the 12 minute rinse cycle. HELP!
Here is a suggestion: First turn the breaker for the dishwasher off for a minute or so then turn it back on. This will reset the controls. After that you should be able to select the cycle you want. Now for information on top drawer acting crazy. I had problems with the top drawer on a model 603I, I found that the control board under the drawer cover (at the upper right corner) had a broken latch. This allowed the control board assembly to drop down at the right side which caused the electronic eyes at the side of the drawer to become misaligned. This was giving false information to the control board indicating that the drawer wasn't closed properly. My problem was fixed by securing the control board back in place making sure the electronic eyes were lined up properly. (Note: The electronic eyes I am referring to include two clear plastic tubes about an inch and a half long to the right of the control board. These tubes must be properly lined up with the led and photocell on the side of the control board) It sounds complicated but if you take the drawer cover off you will notice the control board alignment immediately. Its an easy fix if this is your problem. One way to fix it is to take a piece of string and tie the board back in place. (That's what I fixed mine with and it has worked like new ever since.) NOTE: MAKE SURE THE POWER IS TURNED OFF BEFORE YOU BEGIN THIS REPAIR!
Sep 17, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Won't begin the wash cycle, just continuously drains and fills.
Have you tried pulling out the motor rotor and checking for anything stuck under it? try swapping it with the other drawer. If it still won't go you need to swap over the motor controllers between the two drawers if the fault moves you need a new Motor controller module. Cheers
Apr 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washing machine AEG 72620 not functioning.
Having worked for AEG for over ten years, the fault is a faulty dispenser unit ( top of soap draw) only fix is to replace the unit ( cost approx £45)
Aug 29, 2007 | AEG Lavamat 72640 Front Load Washer
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
483 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
