Question about Sony DVD-ROM DDU1615-ZB 16X IDE 512KB 100 85MS BEIGE WITH SONY LOGO BULK. LEAD DVD Drive
Internal CD ROM will Not Open
I have a internal Sony DVD-ROM DDU1615 on my Dell Optiplex GX620.
Recently when I attempted to open the drawer to play a CD it would not open. The motor to open it was running but did not bring the CD tray out. I had to use the "emergency" opening procedure (the small hole). When I put the CD in the tray, closed the door, the DVD-ROM would not read the CD, the (I guess) opening motor kept running. I again used the small hole to open the drawer to take out the CD. If I close the door the motor keeps running, so at the present time I have the drawer out so that the motor will stop running.
I would appreciate any suggestions as to my next move. Thank you
  • David Hudson Jan 02, 2009
    Thanks for the quick response. I was thinking that replacement would be the solution, just needed confirmation of my initial thoughts, thanks.
    Not being that proficient at hardware replacement, can you recommend a Web site, location, etc that could provide the specifics that I could understand to replace the DVD drive. If I had to pay someone to do the work, what do you estimate the cost to be for the labor? I do not mind paying for work, but do not want to be taken to the "cleaners" for the work.
    Thanks again.
  • David Hudson Jan 05, 2009
    Thanks very much for your help. I really appreciate the support.
    President:
  • 948 Answers
Unless you can do electronic repair yourself and have the schematics for the drive it will be far cheaper and easier for you to simply replace it. Any DVD drive for computers will fit in there. I would buy a new one rather than used so you make sure and get the software with it. Replacing the drive is a 30 minute job at most.
Posted on Jan 01, 2009
  • Dick
    Dick Jan 04, 2009
    In a nutshell what happens is this:
    Remove computer cover
    Unscrew four mounting screws
    Unplug power and data cables from the drive
    Slide old drive out
    Note jumper position on old drive, set new drive to match
    Slide in new drive and plug in cables
    Test new drive and install software
    Screw in mounting screws
    Replace computer cover
    If you take your computer somewhere to have this done expect $75 or so for the labor.
How to boot from a external dvd rom drive on a dell optiplex 3020
Anonymous,
You can plug your device into the USB PORT. Start the computer and press the F12 key. You will then see options that you can boot the system to. USB storage is one of the options.
The computer attempts to boot from the sequence of devices specified in this list:
Diskette drive
Internal HDD
USB Storage Device
CD/DVD/CD-RW Drive.
Onboard NIC
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 14, 2014 | Dell Computers & Internet
Dvd player repair where does rubber band go
Personally I would replace the drive completely - They are very cheap and easy to install. http://www.youtube.com/watch?v=VVjQ7p2_KT0
Jan 07, 2014 | Dell for Optiplex GX620 CD-RW/DVD-ROM...
Dvd eject slot not working on dell optiplex gx620 desktopcomputer
Start Menu, Computer, right click DVD rom, scroll down, click eject. If the DVD in the DVD rom is broken,damaged, remove Drive, disassemble. Try to open the front panel DVD rom door and push the button on the DVD rom drive.
Dec 30, 2012 | Computers & Internet
I recently acquired a used Dell Optiplex 320 desktop computer. When I lay the computer flat, the dvd drawer will open and function. When I stand the computer upright, the dvd drawer will not open. I am...
Sounds like there's something stuck inside the DVD drawer that blocks the drawer from opening if it's not its side. Try turning it over onto the other side, just for a minute, and see if it opens. If it does, there's something blocking the drawer. If it doesn't, you'll probably need a new drive, as that one's literally worn out...which I've only seen twice.
Jul 04, 2011 | Dell Drive for Dell OptiPlex 320...
Gx280 will play cd but not dvd on sony cdrw/dvd 330e. Does not recognise any dvd. Have done all microsoft recommendations to no avail. This apparently does not have a separate driver and is part of...
im sorry but there is no way software can be the problem the only thing it can possibly be is the drive is broken it may have worked one minute then not atall but that is what happens im sorry but with this computer it is a standard drive for a laptop only 20 pounds or so i garuntee the drive is broken i hope this helped be sure to vote
Jan 15, 2011 | Dell for Optiplex GX620 CD-RW/DVD-ROM...
I'vd got not driver
Windows 2000 and XP and Vista and 7 have "built-in" device-drivers to allow you to read "data" files from CD and/or DVD drives.
However, you need software, such as 'PowerDVD' in order to "play" pre-recorded audio/video content recorded on DVD media.
See: http://www.CyberLink.com for information about 'PowerDVD' software.
Jan 08, 2010 | Sony DVD-ROM DDU1615-ZB 16X IDE 512KB 100...
DVD burner drawer will not open every time the button is pressed. When it does open a disk must be in the tray in order to get it to open again.
Most PC DVD/CD drives have a small hole just large enough to insert an unfolded paper clip this will release the rack and pinion drive the the tray will open for you
Dec 09, 2009 | Dell 16X Internal DVD-ROM Drive for...
My CD rom drive won't eject the cd on my Dell Studio Laptop. I press the eject button on the comp, and the click eject on the cd screen, and it makes a noise but nothing comes out.
You may have a cd jammed in your drive. Switch the computer off and on the front of the CD rom drive is a small hole, if you push a straightened paper clip quite hard into this hole it will open the drawer.
Nov 07, 2009 | Dell (0F146) Internal DVD Drive
I HAVE A DELL OPTIPLEX GX620 AND WISH TO KNOW HOW TO INSTALL A DVD REWRITER INTO MACHINE DO I JUST TAKE OUT THE DVD ROM AND INSTALL IN SAME PLACE
You can simply replace the old drive with new one. Make sure you have the jumpers on the same place as the previous one...
This is the jumper image for your reference
Sep 25, 2009 | Dell OptiPlex GX620 PC Desktop
Internal cd writer
yes, you will need to remove and open the rom up and re align the door to gear.
Nov 01, 2007 | Samsung WriteMaster SH-W162C DVD?RW Dual...
Sony DVD-ROM DDU1615-ZB 16X IDE 512KB 100 85MS BEIGE WITH SONY LOGO BULK. LEAD DVD Drive Logo
602 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
