Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is displaying check pump i dont know how.please help.....
  • 242 Answers
Hello , I can help , the bottom front of the unit is removable there should be 2 or 3 screws holding it up , you have to lean the machine back to get to them easier , after removing panel you should see the pump , it has an in and out hose 2-3 inch with clamps on the pump [some have removable filters] have a towel handy for water cleanup. you should not have to remove the pump just inspect it thorouly. Let me know if you have any problems or questions. Phil
Posted on Dec 31, 2008
Need manual for whirlpool front load sport duet model wfw8600sr00
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged / kinked
Unplug washer/disconnect power
Check electrical connections to pump and make sure pump runs, check drain pump filter for strings,sand etc., plug in washer. If this don't work dismantle pump carefully to check if anything is clogging it. If the electrical side of pump is faulty this can easily be replaced, it is normally not repaired.
Washer parts can be found on this site.
www.youtube.com/watch?v=2abTptUYXH8
Mar 04, 2013 | Washing Machines
I have 5d code on my washer
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
The washer stops before rinseing and sends a code 5D.
Hi
Daniel
Aug 23, 2011 | Kenmore HE2 Plus Front Load Washer
The machine start to work ,but then i can see 5d and i don't know what it means
Hi
Daniel
Aug 10, 2011 | Kenmore Washing Machines
I have a F-21 code and I don't know where the drain pump filter is located on my washer its a Kenmore HE-Plus
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it.
Hope this helps... Please post back if you need more information.
Daniel
Feb 16, 2011 | Kenmore HE2 Plus Front Load Washer
Display says sd
Hi
Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Daniel
Jan 27, 2011 | Kenmore HE2 Plus Front Load Washer
What does it mean when the display comes up as sd
Hi
Error code SD or 5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Daniel
Jan 25, 2011 | Kenmore HE2 Plus Front Load Washer
Sd error display. Not slow draining
Hi
Daniel
Dec 15, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washer displays the f21 error code. it did this once before and i had to take the bottom front panel door off to get to a the problem . i can not remember how to get this panel off. can you please...
Hi
Daniel
Dec 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
F-21 error means What?
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal De
