Question about AudioBahn A8000V 400W x 1 Car Amplifier Car Audio Amplifier
Amplifier not working
First of all the amp was playing then it start it to shut down in protect mode but would come back on an play again. then the last time it stop playing it stay in protect mode and was making a ticking sound. someone told me the outputs were bad so i replace the transistor that look to be bad but the nte 2395 that replace the factory install blew as soon as power came on and now the fuses are blow as soon as power is connect to the amplifier. how can i get the right parts for this amp like power supply and output switch.
I agree put in a repair shop or send it back to manufacturer
Posted on May 06, 2007
    Novelist:
    Champion:
  • 218 Answers
Do yourself a favor and take it to a repair shop. It will be alot easier on yourself and you will get your amp back in working condition alot faster.
Posted on May 05, 2007
My sound plays for a while and then the amp goes into protection
Try a different set of speakers or if it keeps going into protection you have a channel going bad.
Jan 14, 2014 | Audio Players & Recorders
Amp not switching on again after switched off for 10 minutes
It sounds like amp's short circuit protection is kicking in. you more than likely have a couple of blown speakers. This drives output to close to 0 Ohms and its shutting down. If it;s not that , the problem is internal and you would have an out put Transistor or a capacitor about to fry.
suppose you could go in and go over solder joints, but don't hold your breath. Next time dont turn it up so loud
Sep 08, 2017 | Lightning Audio Strike S2.600.2 Car Audio...
My ph5000d plays until i turn it up then it cuts in and plays then to protect mode back on why dose it do that its just when i turn radio up
Ok because your wattage is too high for the amp when adjusting a amp with speakers always start like this turn amp gain all the way down head unit bass all the way down and treb all the way up then turn on ur highest listening volume that u like then ajust amp to that hight if will stop protect from happening if continues ur sub is too many watts for amp ok
Dec 13, 2012 | Car Audio & Video
I bought my g-dec jr form ebay last summer and really like this little amp but this past winter I went to use it, it worked for 3 to 5 min and shut down, but the power light just blinked moderately. I...
This amp uses a TDA2050 chip that has thermal protection. It is also a small amp that is NOT capable of high sound levels. If *********** can't stand to be within 5 feet of this amp you are playing TOO LOUD for this amp and it will shut down until cooled off to protect the amplifier chip. This amp is intended for practice. It would be adequate for sensible listening level in a 10 foot by 10 foot room. If you need more sound you will have to get a bigger amp. I would suggest you get a sound meter and verify the sound level. DO NOT exceed 4 hours at 90 DB... I know a lot of deaf musicians that have lost their hearing and they are not much good anymore.
Jul 16, 2011 | Fender G-DEC Junior Modeling Guitar...
Amp shuts off when higher volume
might not have enough voltage going to the amp. depends on the size of the power wire too. had the same problem with mine, had to upgrade my wires, i couldnt turn it up past 14 with out it shutting off and then back on.....
May 12, 2010 | Kicker KX600.1 Car Audio Amplifier
After about ten minuites of playing the amp shuts down and goes to protect mode.. I can then wait 2 minuites and turn it back on and it goes for a while again before repeating the sequence. Is it my...
Amps shut down due to, A: Short circuit, B: Overload. C: Over Heating. It is possible that the Output devices inside the Amp. get too hot during use, Are your speaker "Leads" "Big" enough? Is you Power Positive wire the same, Also as you say, Check your Earth. Sometimes a Fan on the output devices helps.
Mar 10, 2010 | Car Audio & Video
MY AMP TURNS TURNS ON THE PROTECTIVE MODE
The amp is being overworked and is overheating so it is shutting down to protect itself. You could try to add a fan and point it at the amp to help keep it cool. Also make sure the amp is not located where it will get heat from an exhaust pipe under the car for example. They may have external fans that you can attatch to the amp to help cool it. The constant overheating could eventually damage the amplifier.
Oct 09, 2009 | Legacy 2CH 1000W AMP Car Audio Amplifier
Kenwood amp kac-x401m
How long will the bass play before the amp kicks into protection mode and how loud are you listening to it? I've noticed with my amps that if they don't have enough air flow they will get hot and kick into protection mode. They will also kick into protection mode if you are running it at more than it can handle. Check your adjustments on both your amp and the head unit. Make sure you are not running more bass than the amp can handle.
Nov 04, 2008 | Kenwood KAC-9152D Car Audio Amplifier
"Protect" message
It is most likely an amplifier problem. I had this problem before. It went into "Protect" mode and shut down. When I turned it back on, my left channel speakers made a buzzing noise and did the same thing again. I got it diagnosed at an electronics repair shop and they found that the two STK amplifier IC's were bad. One is about $106 and the second one is about $78. I got it fixed for about $200 and works basically like new again.
Nov 20, 2007 | JVC MX-GT88 CD Shelf System
AudioBahn A8000V 400W x 1 Car Amplifier Car Audio Amplifier Logo
101 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
