Question about Maytag Neptune MAH5500B Front Load Washer
Washer stops I Have a front load Maytag Duet washer and it stops more then it runs with the error code "dl" or "f" what can I do to correct this problem? HELP!
    President:
  • 373 Answers
Initially, pls open the lower access panel (bottom of your washer) by removing the 3 torx screws. There would be a sheet that lists the error codes. The panel pulls forward and down, inside mounted on the right side taped to that inner panel would be the above described sheet. Additionally, to my knowledge, this indicates a door latch fault, the machine cannot activate the lock or senses that the door is not closed or the door is not locked.
In some instances, the error code F/DL could be triggered be a loose component. This could be that the plastic fitting on the door is loose and therefore will not latch on the locking assembly or the locking assembly itself is loose. You could then try opening and closing the door a couple of times.
Should this be not corrective, then the logic controller board may require close checking.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 31, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Dl f error code kenmore 11045081400 washer. what does it mean?
Here is a youtube video , you code has to do with door lock assembly ! Troubleshooting and Repairing an dL Error Code on Whirlpool Duet Washer . your washer is the same as this . Kenmore is built by whirlpool !
Feb 27, 2015 | Kenmore HE2 Plus Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Duet front load washer door will not lock. I
Sounds like you have a door lock failure due to the fault code you have or it could be a control brd failure. Sometimes if either fails it will blow the other aswell.
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dl on screencliccking noise from behind washer won't run
That is the solenoid clicking. dl is a door lock error, and you can test and replace the door lock switch, but I am doubtful that will correct the problem. I really hope it does, but I have seen the dl code with the solenoid clicking at the rear of the(Whirlpool Duet) washer before and it was a faulty control board. I hope I am wrong, but... You can try unplugging and resetting the washer. In the case I saw, the machine would reset, but gradually got to a point that it had to be reset numerous times. (too many). Anyway, I hope I am wrong and best wishes. (Don't forget to test the door lock switch. Use a multimeter and check for continuity. A lack of continuity indicates a faulty switch. Hope this helped.
Aug 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sears kenmore elite he4t
Shaking is caused by poor distribution of clothes causing an imbalance. Try the machine empty. If it works well, be aware that you'll have to redistribute your load to stop the shakes.
Dec 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
145 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
