Question about Storagetek L40 DLT Tape Drive
Iam using the Storagetek L40 that the cap is damaged can u provide the partnumber of the cap
  • WALTERIUS Apr 16, 2009
    I think this is L201_428
    Brigadier General:
  • 8,546 Answers
309867203 is the Drawer, Slide CAP
Posted on Dec 28, 2009
Tapes has been stuck in tape drive, how to remove them manually?
This document is very good except that it doesn't discuss the STK-specific "shuttle" on the front of the drive....
The shuttle is how the L700 operates 'drive handle'. Taking that into account, in step 7 of the document you would push in on the shuttle after manually opening the interposer. Let it spring back out at a controleld rate by keeping light hand pressure on it.
http://www.qualstar.com/pin-024.pdf
Jun 09, 2011 | Storagetek L700 DLT Tape Drive
Proximity detector off failed
Hello!
I had the same problem with our Storagetek L40 library and had to get another robotic hand from a company named Instock Inc.
It was an easy fix. I just had to power off the L40 library, take off the old hand and put the new hand on, then turned the L40 library back on, and it worked great after that.
In the hand is a sensor that goes bad after time.
You should be able to find them on the web at instockinc.com I believe, and they should have the hand you would need.
Jan 26, 2011 | Storagetek L40 DLT Tape Drive
StorageTek L20
Yes, you can open the CAP. I believe the menu has a function for that, like Select to Open CAP.
Apr 02, 2009 | Storagetek L20 DLT Tape Drive
StorageTek L20 SCSI ID issues?
Did it ever work for you?
You don't have to assign the scsi id's on the drives. The L20 does that for you according to whatever you set in the drive config menu.
When you say the system 'forgets' the id's does that mean it saw them initially? Does it lose any particular one or all of them? What's the physical configuration - that is, what devices are on which scsi busses and what are their ID's? Any daisy chaining?
Is there a router in the mix somewhere?
Nov 03, 2008 | Storagetek L20 DLT Tape Drive
Error Code 3112
3112
ERR_ITL_DETECTOR_OFF_TEST_FAIL,
The test for the proximity detector off failed.
FRU: LOCATION: CONFIDENCE %:
HAND ASSY LSM 90
LLC LCU 10
Check the hand
Aug 27, 2008 | Storagetek L40 DLT Tape Drive
My Storegtek L80 can't recognize all of its tape drives
That thing required a SCSI terminator pack doesn't it.
If so, is it working properly.
I've had those things go out on me before leaving me to pull my hair out many times.
Jun 14, 2008 | Storagetek L80 DLT Tape Drive
StorageTek L40- Service required Led Blinking always.
Remove the server connection from the library.
power on the library, follow the display in the front panel. The library will do some checks. Note where it fails. Press the select button, it will display the some code message. With the error code refer the manual.
Sep 18, 2007 | Storagetek L40 DLT Tape Drive
StorageTek L40 Tape Library
sounds like your robot is stuck or something may have dropped onto the track on the floor which is restricting it's movement.
Jul 26, 2007 | Storagetek L40 DLT Tape Drive
Service required led blinking
You will need to get a StorageTek engineer out onsite to have a look at the problem, the light will not dissapear until resetted by a engineer.
Jul 10, 2007 | Storagetek L80 DLT Tape Drive
Storagetek L40 DLT Tape Drive Logo
118 people viewed this question
Top Storagetek Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Storagetek Computer and Internet Expert? Answer questions, earn points and help others
