Question about Fujitsu C600 (LKN:GBR-651211-014) PC Desktop
Monitor display too low
When i finished install windows xp sp2,the display of the monitor turns in very low pixel and i cant increase the pixel and it stays in 4bit display.how can i back it to normal display?tnx
    Novelist:
    Champion:
  • 233 Answers
Was this a re-install? It sounds like Windows does not have the drivers for your graphics card. Go into Device Manager and see what it says in there. It will give you info about the drivers or lack thereof. You can probably go online and get the drivers you need.
Posted on Jan 02, 2009
I recently got a new Computer machine on Windows 7, but I have kept my AOpen F205-12S Monitor. Unfortunately for some reason the resolution cannot go to the monitor's maximum. It stays on 1024 x 768 and I...
go to control panel ,display, monitor , move the slide for pixels , apply and ok
if you want bigger , there is a tick box as well 100%,150%
adjust that as well
Apr 27, 2017 | AOpen F2705 17" LCD Monitor
Tip
Set Default Windows Font to 120 DPI for use with a large HD Monitor
Most users have either a 17" TFT montior OR an older CRT of the same size which works really well on the default 96 DPI and a screen resolution of 1280 x 1024 pixels OR the default 1024 x 768
However if you have a larger HD Monitor that will allow for a much higher pixel definition in line with 1080i and 1080p Televisions you might need to increase the DPI to 120 or some other custom setting to do this you need to right click the desktop and navigate to;
Display Properties > Settings > Advanced > General and you will see the pulldown menu to change it to Large Size.
It may ask you for the Windows CD however the files that are required should already be there unless you installed the Operating system from a minimized set of cabinet files on a slipstreamed CD.
on May 13, 2010 | Microsoft Windows XP Professional
Need to increase font size without effecting pixel clarity
The first step for optimal readability is to set your PC's graphic output to the native resolution of your monitor.
The Samsung 2033SW is a little unusual in this regard since it provides a matrix of 1600 x 900 pixels, which is not very common.
If your graphics board has DVI output, I'd also make sure to use a DVI cable to connect to the monitor instead of VGA.
Windows XP and above support a font rasterization technology called "ClearType", see http://en.wikipedia.org/wiki/ClearType. This page also provides references to the ClearType tuner PowerToy for XP, which is available to Windows users at no extra charge. Windows 7 has a control panel for ClearType out-of-the-box.
If you still need to increase font size, you can increase it from the Display Control Panel, too, "Medium" font size scales to 125'%, "Large" fonts to 150% the normal size.. Changing the DPI (dots per inch) setting in the monitor control panel cannot be recommended since some software cannot cope with alterations here (dialog boxes or user interfaces with text in wrong places or sticking out of the window... yeeks.)
Feb 07, 2010 | Samsung Syncmaster 2033SW Monitor
Monitor Philips 17 Cannot increase pixel from 640 x 480
Go to your control panel and click on monitor. From there you can adjust the pixel settings.
Dec 13, 2009 | Philips Audio Players & Recorders
I have a dell with windows vista. the monitor is 20 or 21 inches wide screen. I recently had a friend try to install windows xp but at the last attempt he tried to reformat my computer & install it xp...
You can adjust the screen resolution to increase the size of the image to fill the screen.
Go to the Control Panel - Display - Settings and adjust the screen resolution to 1280 X 1200 pixels. If this still doesn't fill the screen then increase it further say 1600 X 1200 pixels even higher if necessary.
Aug 19, 2009 | Dell Computers & Internet
My problem is the displayed windows on my monitor/screen
Press the F8 key when windows is booting up from a power off situation, select "safe Mode" you should get a Display then,(NO Video driver(except windows generic) driver is load in safe mode). Set your display to the LOWEST resolution.. Reboot. See if you have a display with the driver set Low. If so, increase the resolution on level at a time until you encounter a problem. If you do not select Yes when windows asks if you want to keep this display setting, Windows will revert back to the last setting you selected yes for.
Apr 12, 2009 | Microsoft Windows 2000 Professional for PC
Not working 1024 by 768 pixels resolution
reduce the number of colors until you can get a resolution that works the monitor cant handle the number of colors and the number of lines of resolution this is a common problem with older monitors.
l8r
Nov 13, 2008 | LG Studioworks 440SI 14" CRT Monitor
Flickering pixels
plug it in all the way thats how i did it
Oct 30, 2007 | NEC-Mitsubishi Nec Display Solutions...
Fujitsu C600 (LKN:GBR-651211-014) PC Desktop Logo
79 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
