Question about Minolta Di3510f Bizhub Copier
Problem with my sharp AR 336 code F1-05
Hi need help with code F1-05 sharp copying machine thank
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Hello, this is a sorter bin home sensor fault. First shut down machine and disconnect all power. You will need to remove the front and rear covers of the sorter, then you will have to manually turn the spindles/ cams as to more the actuator off of the home switch. Once you have released the home switch/ sensor, give a little extra space -- apply the power and watch. The cams should move the bins to switch/ sensor and reposition. Once you have made sure that it is working, shut down the power and disconnect power. Install covers back onto sorter and apply the power. If, when the power is applied before you installed cover, if the cams keep driving and do not stop and code comes back, that bin home switch will need to be replaced.
Posted on Jan 05, 2009
How to fix a H5-02 code on a Sharp AR-336
input C + interrupt + 0 + interrupt +start +14 +start
Dec 05, 2013 | Sharp AR-C160 Color Copier
Sharp ar 336 copier
remove the fuser unit and clean the thremister, but 1st turn machine off, upon reinstall of fuser enter service mode p*c* and choose 014 to reset the code, if that doesn't work you may need a new fuser
Nov 09, 2013 | Office Equipment & Supplies
Salut je cherche solution par rapport à un code Code H3-01 sharp AR 336
The problem is in your fuser section. You may have a bad thirmistor or heater lamp or the main pcb. Good Luck...
Jan 22, 2010 | Sharp AR-M237 Copier
HAVE A SHARP AR-336 WITH A CODE H3-00 HOW DO I FIX THIS
You can try this it works for older Sharp models.
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  5. your display will stop flashing H 3, if not re-enter the keys again, some machines are temparmental, when it goes blank
  6. enter 14
  7. press the start key then turn it off and back on, if it comes back with an h code there is a problem with the heat section and will need a service call and probably parts.
  8. good luck
Apr 21, 2009 | Sharp AR-M237 Copier
Ar 336 sharp copying machine code F1-05 please help
If you have a finisher on that unit ,that code is upper limit switch problem. Check to make sure your upper tray is in the right position. Otherwise your either your tab is broken or your led is popped.
Jan 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
REPLACING THE TONER
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Sep 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
My Sharp AR-336 copier gives two error codes: 1)is F2-37 & 2) is U2-00. The U2-00 I can clear everytime. The F2-37 won't clear for hours. The only things is to leave it unplugged for several hours...
when you turn on the machine it rotates and takes severaal readings from different sources. one of them is for the drum, adjusting the seperation to the age of hte drum. So as the drum ages with the amount of copies it automatically adjust it self. Have the tech replace that sensor (if they haven't done so) or maybe it just has toner on it giving false readings.
http://www.copier-help.com/copier-help/ecs/sharp/ecssf2216.html
Aug 07, 2008 | Sharp Office Equipment & Supplies
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316
Hi, from memory, the secret test commands are: # I CA #, then 81 to reset main copy count.
Cheers
Andy
Jan 07, 2008 | Sharp AR-5316 Advanced Digital Imager...
71 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
