Question about Wharfedale DVD-M3 DVD Player
Usb error my in car cd player will not play my mp3 player. it keeps saying "usb error" i know the cd ploayer is fine as it has player a differant mp3 player ... i know the mp3 player surports this type of use and i know the songs on the mp3 are in the right fomat (as they are identical to the songs played on the other mp3 player (that worked ) i also know the usb lead that i am using is fine ... any surgestions????
  • 1,800 Answers
Check new USB cable or resolder the USB connector
also change the usb plug istelf.
Posted on Apr 28, 2009
When i plug my usb into my pionner car cd player , i read error 19 what does mean ?!
This is what it says in the owners manual.
ERROR-19 Communication failure
Perform one of thefollowing operations-
-Turn the ignition switch OFF and back ON.
-Disconnect the USB portable audio player/USB
-Change to a different source. Then, return to the USB portable audio player/USB memory.
Mar 09, 2011 | Pioneer FH-P8000BT Car CD/ MP3 Player
My cd player keeps saying error 3 what does that
its because of data memory corrupt.. u might need to flast your memory of ur cd player
May 28, 2010 | Aiwa CDC-MP3 CD Player
Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Sep 23, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Clarion DXZ385USB will not play from the usb input
It is not compatible. I had the same receiver and mp3 player. according to the Clarion website, an "ERROR 5" is the message for a compatibility problem. You probably got an "ERROR 2"(format problem) when you had the player plugged in and then cycled through the sources(that's how I received the error).
I have since bought an Ipod and the USB input works just fine. Clarion says the deck is MTP compatible, but it will not run a lot of MTP devices. Only Ipods and certain memory sticks. The Creative Zen Vision M is read as an MTP device when it it plugged into anything like a computer, Xbox 360, and the Clarion USB receivers. The Clarion units even attempt to read it as an MPT device, but will not play. It is not an issue with the receiver or the MP3 files. The Creative Vision M is not a compatible device, sorry.
May 29, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Flash card not playing
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 04, 2008 | iLO (2 GB) MP3 Player
LineOut
Yep. Take it to the nearest Sony Repair facility, usually when they say that there in an internal problem with the audio in from the laser to the audio ic
Don
Jan 02, 2008 | Sony CDX-R3000 CD Player
Ilo 2gb mp3 flash player cd problems
Nov 26, 2007 | iLO (2 GB) MP3 Player
Will Not Play CD-Rs Part Deux
Checked specs- YES -supposed to play MP3's. Did you try other MP3 Audio disks in the DVD? You can try the MP3 disk in your computer to make sure it is OK. If it plays in the computer, have to suspect a problem with the DVD unit - probably the converter IC.
Aug 20, 2006 | Samsung DVD-V1000 DVD Player/VCR
Will not play CD-Rs
DVD players will play CD's and MUSIC CD-R's. Some will play MP3's IF the unit is so designed. You would see the 'MP3' logo on the front.
Wharfedale DVD-M3 DVD Player Logo
94 people viewed this question
Top Wharfedale Televison & Video Experts
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
