Question about Toshiba G15-AV501 Qosmio Notebook
Toshiba Qosmio g15 av501 Bios password lost
I haven't used this laptop in quite awhile and I have forgotten the bios password that I set on it back then.Is there anyway that I can get it reseted via cmos reseting? if so,where can I find the cmos battery on this laptop.My manual doesn't show any information on the wherabouts of it so I thought i'd try asking on here. Any input or suggestions is greatly appreciated.Thanks in advancee
    Novelist:
  • 84 Answers
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on May 19, 2009
I was given a qosmio G15-AV501, but it appears to be overheating about 10 minutes of operation. It will run for a little while, then just shuts down. Between 5 and 15 seconds before it turns itself off I...
No particular problem with your unit. In your case it appears that the fan isn't operational - open the laptop and replace it.
Also check in the BIOS the shutdown temperatures, they might be set way too low.
Sep 08, 2010 | Toshiba Qosmio G15-AV501/R Notebook
My laptop wont start its a toshiba g15
have you tried pulling each stick of ram individually?
if there is still no boot then its safe to say that the motherboard or one of the two video cards has failed. its a pretty common on the qosmio g series
Nov 03, 2009 | Toshiba G15-AV501 Qosmio Notebook
Hard drive not showing in bios
It appears that your #2 hard disk has died. To test if it is faulty, remove the #2 drive and connect it to an USB hard drive adapter and plug it into the USB port of a working computer. If the computer see it as an external USB drive and you can see the folders and open the files, then it is OK and the fault is possible the disk controller.
If the hard drive is not recognised then it is faulty and needs to be replaced.
Jun 27, 2009 | Toshiba Qosmio G15-AV501 Notebook
Whats the trick to get into the BIOS of a Qosmio G15R-AV501?
Try F2 as soon as you turn on the laptop or even try F12 cause that would get you to the boot menu and you can choose enter setup from that point.
Feb 04, 2009 | Toshiba G15-AV501 Qosmio Notebook
I have a Toshiba Qosmio G15R and I need drivers
I went to the Intel site and downloaded the Intel® PRO/100 VE Network Connection driver here. It worked great. Now if I could find the right audio/multimedia drivers I'd be happy. Hope this helps.
Dec 26, 2008 | Toshiba G15-AV501 Qosmio Notebook
My daughter put a password for the bios and cant remember it.
Try holding down the "Left Shift Key" when turning on the system
Nov 28, 2008 | Toshiba Qosmio G15-AV501 Notebook
Forgot bios password
ok first off im assuming u forgot the old one or a friend is playing a cruel joke or something along these lines. :-) ok the only way to reset it would be to take the bios battery out witch means you have two options do it yourself and pay nothing or pay someone online or take it to a shop (If you dont have knowledge of the internals on a computer i do not suggest you take ur labtop apart exspecially considering the retail price of your labtop i own one also lol but seeing that i awnsered ur problem how about u awnser mine lol its about a piece that comes with the labtop when bought
Oct 21, 2008 | Toshiba Qosmio G15 Notebook
Toshiba Qosmio G15-AV501 red lines in lcd
See the below "copy & paste from another member" I don't know how sucessful these other owners were, but it's worth a try:
PNWSolutions
Rank:master_s.gif Master
Rating: 77%, 15 votes
I had the same problem, what you need to do is call Pamela Saunders at Toshiba Corporate in Irving, CA and she will get it repaired for you at no cost to you regardless of warranty. This is a bad batch of computers.
The Phone Number is: 800-457-7777 or 949-462-6000
Aug 24, 2008 | Toshiba G15-AV501 Qosmio Notebook
Toshiba G15-AV501 Qosmio - no video 1) Following is what I have tried - and did not work, by the way everything I installed had worked for over a month w/o problems, until...no video The problem began when...
Well, I have good news for both of us.
Not only did I find a fix, it's free.
The F15 and G15 series Laptops (which we both have), have an Out-of-Warranty fix (for free). This is not normal, as you may know. The reason it's free, the motherboard is defective... I just called today and they're still replacing the motherboard for free!
Go to the Toshiba website and call their Tech Support number. They'll tell you it's out of warranty and they're going to charge you, just ignore all that. When you get your foreign tech support person on the phone, tell them you've read that the F15 and G15 series were defective and were being replaced free (even without warranty). They'll get your product number of the laptop, process the order, ship you a box (pre-paid shipping), you ship the laptop to them, they fix it, they ship it back, you're back in business!
FREE!
Aug 14, 2008 | Toshiba G15-AV501 Qosmio Notebook
Toshiba G15-AV501 Qosmio Notebook Logo
954 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
