I want size (measurement) of Model No. FSAH 801 CR whirlpool Washing Machine
  • 15,935 Answers
3.2 cuFt
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
Will LAB2700LQo pedestal fit my Kenmore model 110-47532602 or 1108752601
Even though the Sears brand is made by Whirlpool, the 110 series is an exclusive line. IT is not likely to fit. You will have to measure the base and mounting holes on the pedestal and the machine.
Jun 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
The machine fills up then will not compltete the
Assuming that this is a basic top load, direct drive, neutral drain machine, the following is the Whirlpool (Kenmore) installation and maintenance manual with a very good troubleshooting section.
The problem seems to point to either the timer or motor.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If you need to tear the machine apart, please see an excellent description from GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Sep 20, 2009 | Kenmore Washing Machines
What cu. ft. size is my Whirlpool top loading washer model # LSQ9549LWO?
hi there. the best way to determine this is to measure the inside length, height and width and you will get cubic feet. Just be sure to convert each measure to feet. For instance 2 feet 4 inches = 2.33 feet.
Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Can you take water supply to american fridge freezer from cold water supply to washing machine? model no whirlpool 20RID4
you can buy a "y" piece that will connect to the washing machine's supply then connect both to that. They are both the same size fitting threads.
I hope this helps
May 09, 2009 | Whirlpool ES5FHAXS Side by Side...
My washing machine will not spin
The same thing happened to my Maytag washing machine and the first thing I checked was the air pressure hose. A small piece of tubing that ran from the bottom of the tank to the indicator for size of load. Could either be blocked or detached at one end. To access it I had go to the back of the machine. I found the diagram on the web when I search for model and "agitator not spinning". Good luck.
May 04, 2009 | Whirlpool Washing Machines
Cannot find the model number on my Whirlpool washing machine. It is a top loading machine, with such features as: 4 Load size, 4 Tempature settings, 8 cycles, 4 speed combinations, commercial quality....
If this was a scratch and dent model, model number may have been removed prior to sale. If not, you should find it on the back edge of the washer at the very top as you look over the back of the machine. If you can't find a model number, bring the part(s) you need to a servicer. They may be common parts or there may be some identifying numbers on the parts themselves. Good luck.
Sep 01, 2008 | Whirlpool Washing Machines
check if the springs for support and leveling are in good condition and mounted properly039ec06.jpg1bd62d6.jpg
Dec 28, 2007 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
