Question about Fuji FinePix S5700 Digital Camera
My fujifilm s5700 has a small problem... The flash itself works fine, the light that is, but it does not automatically pop up. It pops up about a milimeter or so, but not enough to be functional. If I hold the flash upright it works fine, its just annoying. Just curious if this could be fixed fairly simply? help!
  • 4 Answers
The Flash Spring mounting breaks
Anyway if you are brave and handy you CAN fix this.
First remove the back of the camera - 3 screws in battery bay, 1 in the side above the memory card door, The two rear most on the bottom, two in the USB/video door, and the rear most on the left hand carry strap bracket.
Carefully prise the back rearward about 5 to 8 mm.
Now take a look at the two screw holes under the flash (when popped - or flopped out now that is broken) now go and bend a screwdriver of the type you used for the previous screws - you will need a 90 degree bend very close to the tip to fit in this gap and be able to turn the screws a few degrees at at time.
A little at a time lock the screwdriver into the screws and undo until the flash cover comes off.
You can then slide the shaft out of the flash to release the spring which will have the end that should fit into the broken bracket now sitting proud..
Make a suitable U shaped bracket that will slide over the broken plastic bracket and drill a tiny hole in the side where the spring will clip in.
make sure it fits really well and then epoxy into position.
Getting the spring back in is a fiddly job - I found the best way was to fit the end of the spring into the new bracket, slide the shaft just into the spring - the lever the other end of the spring down into the back of the flash body and then slide the shaft all the way into place.
I did have to file down the little plastic "blade" inside the lid which presumably is designed to assist the the (now broken) bracket from breaking....
reverse the dis-assembly and now you should have a working flash
Posted on Dec 08, 2010
    Problem Solver:
  • 4 Answers
Many of this cameras have this problem, sometimes it doesnt pop at all. Try pressing it down and to the right. It should work fine. do not worry, your camera is fine, in a way of saying. Poor build that is all.
Posted on Jan 22, 2009
Flash repair on fujifilm finepix s5700
You need to take Camera to Camera shop, but the cost of repair may be more than Camera is worth !
Feb 14, 2015 | Fuji FinePix S5700 Digital Camera
My flash will not return into the camera and just keeps popping back up when I push it down.
Kindly check the flash option is automatic or manual select it to auto flash if not solve reset the cam
Jun 10, 2014 | Fujifilm FinePix F800EXR Digital Camera
Canon rebel xti flash pops up but says it was obstructed
This is a problem known by Canon, you will have to have it serviced.
Oct 30, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
Oct 21, 2009 | Nikon Cameras
Fuji s5700 my flash is not popping up on auto
had a run in with fuji myself.. if it's going to cost that much to fix. you might as well get a new camera. they don't seem to care to fix or replace parts on their cameras
May 30, 2009 | Fuji FinePix S700 Digital Camera
Flash isnt working finepix s5700
try to pull it up to get it out and then choose the lightning button to activate flash....
Nov 11, 2008 | Fuji FinePix S5700 Digital Camera
Accessories for Fuji Fine pix S5800
You Can not put additional flash on S5600, S5700 and S5800.
Jun 18, 2008 | Fuji Finepix S5800 Digital Camera
Colour tone issues with Fujifilm Finepix S5700
It sounds like the sepia tone is most likely caused by the tungsten lights in a regular room. Without flash, the only source of illumination indoors is artificial light (unless window light is dominant). There is a way to color balance the camera to approximate sunlight through the manual settings. Look in the menus for "white balance". You'll need to take the camera off of the fully automatic settings first. Move the cursor up or down while looking at the image and you will see the color shift. when you find a color balance you like for that particular room's lighting conditions, hit the OK to lock it in the activated position. Remember to go back to "auto" white balance for most shooting, especially outdoors, or everything will take on a wierd color cast.
Jun 03, 2008 | Cameras
Automatic flash problems
I have the same problem as Irichard, in that the flash won't pop up automatically, the camera wont work when you pop it up manually all all modes that allow flash photography do not work.
Nov 01, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Fuji FinePix S5700 Digital Camera Logo
444 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
