Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Daewoo regrigerator - Multi flow -
The message on the door keeps saying "Clean" but we don't have a manual to fix this problem. Fridge was leaking water but that seems okay at the moment, but the fridge keeps running constantly and not getting very cold, although the freezer is freezing ice block okay.
JUst want to know how do we get this clean message off.
Is there a manual available?
  • 8,197 Answers
Go here at the bottom you will find yhe manual you need the model # though.
http://www.e-daewoo.com/owners_manual.asp
Good Luck And Please Rate FixYa!
Posted on Dec 31, 2008
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
DAEWOO FR-661NW GETS HOT
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
Jan 24, 2014 | Danby 16.7 cu. ft. / 473 liter Upright...
Stench from back of fridge
Sounds like a regrigerant leak. Have it checked by an appliance tech.
May 26, 2012 | Siemens Bosch Neff Integrated Fridge...
I lost manual book for my fridge,(daewoo) How can
Go to this site and after open the page, click on down "Download Page"
http://www.pdf-manual.com/user-guide-instruction-owner-manual-daewoo-fr-094r%28ss%29-23349.html
Hope, you got it.
Jan 23, 2011 | Daewoo FR-094R Refrigerator With Ice Box
Fridge not getting cold return air duct keeps freezing
make sure back and bottom of fridge is completely clean, if so you might be low on freon
Oct 23, 2010 | LG LRFD22850ST French Door 22.4 Cu. Ft....
The pan underneath keeps filling up with water and over flowing. I can't find a leak anywhere
Your looking for a water leak and what you have is a air leak. One of the doors are not sealing right. Check the door gaskets for a good seal, clean the edge of any dust. Also pull the fridge out from the wall good remove the rear cover and vacuum out the coil on the bottom. Having a good clean coil helps to evaporate the watter in the pan. If not enough air flow over the coil the pan may stay full longer. Humid air gets pulled into the fridge thru the door seals and during defrost drips into the pan, where the heat from the bottom coil helps to evaporate that water. Other causes are too many door openings, keep that freezer door closed as much as possable in the heat of the day.
Aug 29, 2010 | Kenmore Refrigerators
Fridge freezer leaking
there should be a drain pan under in unit. it could be missalinged or the drain tube may have a hole in it. mice are good about this
May 22, 2010 | Daewoo Refrigerators
Hoover prestige electronic surround multi flow: how to clean?
hoover surround multiflow restige electronic i have no manual pls help clean in red displayed and water pooling in the bottom.
Oct 10, 2009 | Hoover Refrigerators
Help needed to clean the filter of fridge
You need to clean your coils - that is why your refrigerator is not cooling as well as it used to and will also solve the clean light. Whether they are underneath unit by taking off the kick plate or behind it is the same problem.
This should be done every 6 months (or more if dusty enviroment) to keep the problem was reoccuring. The brush accessory tool of a vacuum works best usually.
May 05, 2009 | Daewoo Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
393 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
