Question about Goodmans 217NS TV
Goodmans tv/video/dvd all in one
Perfet picture on tv perfect picture on dvd black & white picture on video perfect audio can u help please
    Novelist:
    Champion:
  • 275 Answers
Perfect picture on TV, DVD and VCR, but no color means you have selected the wrong color system.Since you are in the UK, make sure that the VCR Color system is also set to PAL. Perhaps it is wrongly set to SECAM?
Posted on May 12, 2007
When playing a dvd it black and white no color
what output connection are you using? (svideo can cause this if it's not properly supported on both devices)
What format is the video stream NTFS or PAL? some devices don't like one or the other format. This issue could be linked to your dvd player or your TV so please investigate what I have suggested and post back here if you have no luck :O)
Jan 30, 2010 | Bose Lifestyle 38 System
Picture is black and white with a dvd movie
If you're using the 3 component cables for video, one is probably defective or not connected well.
Dec 29, 2009 | Bose Lifestyle 38 System
I am trying to play back video from Sony Handycam on tv, the sound is perfect but i have no picture, im sure it must be something simple. i have handycam a/v out attached to the yellow red and white...
    First remember that the "Yellow" is for video signals the Red and White are for audio.
    first connect the camera leads directly to the TV. First yellow connector of camera attach with the "Video in" of Tv and same as Red and White of camera as Audio IN of Tv. And you will both get sound and audio.
     Now same as connect the camera connectors Yellow in Video In of the DVD and Red & White For Audio In in the DVD, Now a new lead connect to DVD out Video "yellow pin" to the TV Video IN ans same as Red & Whit in TV IN. By this procedure you will get the Video and Audio from your camera.
     Hope this will help you.
     Thanks.
Dec 01, 2009 | Sony Handycam DCR-TRV245 Digital-8 Digital...
How to connect a dvd player to lcd tv
Your DVD player's output is Composite Video (the yellow connector) plus stereo audio (the red and white connectors, for right and left audio)
The inputs on your TV are for Component Video, which splits the video signal into three cables (Y for brightness, Pb and Pr for blue and red, respectively)
Check your TV to see if it has a composite input (single yellow connector, labeled "video" or "composite")
And be sure to let me know if this helps!
Oct 24, 2009 | Televison & Video
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD plugged into red, white and green(Yellow) TV imputs, results
Yeah no color coz its black and white. Color coding commonly yellow wire for video, red and white wire for audio. It should also be from DVD to TV, video out and audio out going to video in and audio in. And switch the TV to play video and the audio inputted. Maybe TV/Video Switch or button.
Hope it helps
Apr 06, 2009 | Jensen TS2750J TV
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
DVP642 DVD Player is only working in Audio mode
Mine does the same. Cannot get a picture using the Yellow RCA output. Use an S-video cable if you can - it should still work. If you get a black and white picture using the S-video output, go to MENU > VIDEO page and change the output from PyBywhateveritis to S-video and the color will come back. I only found out mine was broken when I needed to use the s-video cable for something else and tried switching to the Composite Video (RCA) to no avail no matter how many cables or TV inputs I tried.
Mar 15, 2008 | Philips DVP642 DVD Player
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
Goodmans 217NS TV Logo
133 people viewed this question
Top Goodmans Televison & Video Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
