Question about ASUS M2N-E Motherboard
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother board utility, its running from last more than 1 year, now when i reboot a system it has some error message in sata socket 3, when i turned of or pull out the 3 socket hard disk which is a part of the raid the error message changes and when i turn on the socket 3 hard disk the same old error message occured that this disk is not functioning properly, using the utility i choose the option to rebuild the 3 port disk but nothing happens, please advise
    New Friend:
  • 111 Answers
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Posted on Jan 09, 2009
Gigabyte combo motherboard
I've had an Asus P5Q-SE for about 7 years now and it's a solid board. It has 4 memory slots, 2 IDE ports, 6 SATA ports, 6 USB ports on the back with headers for 6 more via front panel or rear expansion card and 5.1 sound, as well as an embedded (although VERY basic) operating system, onboard antivirus and a couple other goodies in the ROM.
I'm sure there is an updated version of this board by now which would offer more features but I don't even use all the features of this board. Regardless of which board you get, it will have to be socket 775 and support DDR2 if you want to keep everything else
Jul 13, 2013 | Gigabyte GA-8I865GME-775-RH Motherboard
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
I need a diagram of the ASUS M2N-MX Motherboard
A simple and inexpensive motherboard for the enthusiast or the first time builder, the Asus M2N-MX is a great starting point for anyone wanting to build a system or upgrade their motherboard. Designed with the small form factor case in mind, this motherboard will fit into most small desktop systems. Equipped with an AMD socket AM2, suitable for Athlon 64 processors, including the X2 and FX series, it's more than capable of handling anything you can throw in there.
Using the Nvidia GeForce 6100 chipset with integrated graphics in conjunction with up to 4GB of DDR2 memory, the M2N-MX is perfect for those that don't need a discrete graphics card. Audio's onboard, too: hear crystal-clear quality from all your audio - MP3 playback, home theatre, advanced gaming, VOIP and more, and never worry - SoundMAX high-definition audio is there to enhance your experience!
It also includes a 10/100 Ethernet port, onboard 5.1 channel sound, and 4 SATA ports. And because of those 4 ports, by adding multiple hard drives to the system the M2N-MX supports RAID 0, 1, 0+1, 5. The M2N-MX has multiple expansion slots to use including one x16, and one x1 PCIe slots, and two additional PCI slots. Build a powerful system -- the Asus M2N-MX is a great foundation.
Dec 04, 2010 | ASUS M2N-MX Motherboard
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Problem
there is a problem in your power supply, one of the capacitors maybe busted, it also happened in one of my computers, that is one of the most problems in computers specially when you used this for a long period of time. try to replace this with a new one.
Nov 29, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Strange problem
hi
have you tried putting a fan for the hard drive? although it may sound strange, auto shutoff happens in rare times.
i had this harddrive before that also had this problem, but eversince i transfered my pc to my moms room( airconditioned), ive noticed it doesnt have that problem anymore.
hope this helps.
IDE ports in asus m2npv-vm & m2n-mx motherboards
hi, i have a couple of those boards. they have 2 ide ports on them and 4 serial ports. if youu do get the m2npv-vm, one thing that is weird about it, one faces up from the board and the other lays flat off the edge. also the ports are right next to each other and the polarity (which side you put the ribbon cable stripe on) is opposite each other. so if you don't use a keyed ribbon cable you might hook them up wrong.
Aug 22, 2007 | ASUS M2NPV-VM Motherboard
ASUS M2N-E Motherboard Logo
151 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
