Question about Zanussi WJS1265W Front Load Washer/Dryer
New belt kept on slipping out. What could be the problem.
  • Arthur Danner May 11, 2007
    I have taken the nut from the back to get to the bearings but Can't see how to get them out.
    What are your thoughts on that.
    President:
  • 1,462 Answers
Either wrong belt or bearings very worn or collapsed so pulley is running out of true and throwing belt off. can also be caused by the bearing spider being broken
Posted on May 04, 2007
How do i adjust belt tension
Technically you don't.
The serpentine belt is kept tight by a spring loaded pulley called a tensioner.
If the belt is slipping, either the belt has stretched and needs to be replaced, or the spring in the tensioner has failed and it needs to be replaced.
Jan 09, 2013 | 1999 Ford Taurus
When it rains hard my 2000 dodge gran caravans bat. Lt. comes on and i start losing my power steering why
The serpentine belt is slipping when wet. Either the plastic shield on the bottom of the van is missing, or the belt is not being kept tight by the tensioner.
Dec 12, 2012 | Cars & Trucks
Broke engine to deck belt after only 33 hours of mowing. Swisher needs to resolve this problem. Will they stand behind their products?
I also had the same problem, belts kept breaking after a short period of time, and the problem turned out to be the four bolts holding the engine to the frame loosened to the point the engine was tilting and letting the belt slip. Once new bolts with lock washers were installed, all has been good.
Sep 19, 2010 | Swisher Zt2350 Zero Turn Radius Tractor
Belt seems to be slipping
As a general rule, the belt should be kept as loose as possible. However, the belt must not slip on the rollers in normal use. Possible overtension can be quickly checked by walking on the belt at a speed of 3 mph The belt must slip on the front roller if you brake the belt with your feet, holding onto the hand rails, while you walk. If the belt does not slip, the tension is too high and the rear roller must be loosened. The belt tension and alignment is done by adjusting the rear roller position with the attachment bolts at the back of the treadmill a 1/4 turn at a time until correct tension attained. T
May 13, 2010 | Tunturi T60 Folding Treadmill
Timing belt on 1997 Dodge Caravan keeps slipping off after new installation
I had a 1998 dodge caravan that kept doing the same thing, it would actually break the belt when it come off. I fixed this by buying a slimmer belt, you know, one that is not so wide. I put a slimmer belt on mine and I never had another problem. Maybe this will help.
Nov 06, 2009 | 1997 Dodge Caravan
Traction Belt (new) continues to slip off of drive plate.
Sounds like you may need to replace the pulley as well. It has likely worn out of specification.
I recommend that you contact your nearest authorized service center, or contact Toro directly for assistance.
I trust this information proves useful.
Oct 02, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Serpentine belt wont stop slipping
sounds like your belt tensioner pulley may be defective, also check all the pulleys for excessive play in the pulley bearings, these are the most common causes.
Feb 05, 2009 | 1994 Jeep Cherokee
Zanussi WJS1265W Front Load Washer/Dryer Logo
62 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
