Question about Microsoft Xbox 360 Controller
Changing controller player 2 slot with XB360 wired controller
I need to know how to change the xbox 360 (wired) controller for windows, so that it is in the player 2 position.
  • Bazzeil Feb 07, 2009
    I have the same issue, I know in Left 4 Dead if you quickly (and i mean REALLY quickly) unplug and plug in the controller immediantly at the end of the level load screen, it will take player 2 for split screen (google it for full instructions)
  • Anonymous Mar 16, 2014
    where to get a wire for a xbox 360 wired controller
  • 4 Answers
Alright, I've been playing around with it and i found a way.
You'll need to be pretty quick with it. The best way i found is to hit the xBox button, then quickly unplug the controller and plug it into another port.
(You will have to press the xBox button, it will give you a better chance at getting this, it'll tie up the driver for a split second)
This will get you over to player 2. If it doesnt work the first time, try it again a few times, switching ports each time.
Posted on Feb 07, 2009
  • 1 more comment
    After a restart and further testing, i would like to clarify my submission. You will need to wait for the controller to take its player slot (the controller indicator light) before switching it to another port. It turns out it is not entirely neccesary to press the Xbox button, but i still reccomend it.
  • YOSSI2010 Jan 26, 2011
    the best way is to use nulldc - dreamcast emulator or anything that use the x360 controller open it plug the controller plugin use the x360 controller boot the emulator (even without game just bios)
    and that unplug and plug back THATS IT ALWAYS WORK
  • Maiochine Aug 27, 2011
    Hi guys I am having trouble to get this to work... I have brand new 2 wired controllers Microsoft xbox 360 and when I connect them both they show up as player one and only one of them is working! I tried to do as you mentioned in the first reply of the topic: I had one controller connected and the xbox off I pressed the xbox start button and I quickly plugged the second controller but nothing changed still on player one on both controllers. I pressed again the xbox button to shut it down and I quickly plug out one of them and plugged it into another USB port and no joy !!! Would you please tell me what I'm missing ?
    Many thanks
Walmart controller not working on my pc
Set up a wired controller
Step 1: Install the Xbox 360 controller for Windows software
Use the installation CD that came with your Xbox 360 controller for Windows before you connect the controller for Windows to your computer:
  1. Insert the installation disc in the CD or DVD drive of your computer. If the Setup program does not automatically start, change to your CD or DVD drive and run the setup program.
  2. On the setup screen, click Install.
  3. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
If you don't have an installation disc for your Xbox 360 controller for Windows, you can download and install the software online:
  1. Go to the Software Downloads section of the Microsoft Hardware website.
  2. Select Gaming as the product type.
  3. Select Xbox 360 Controller for Windows as the product.
  4. Select the version of Microsoft Windows you are using on your computer, select your operating system language, and then click Download.
  5. Click Run.
  6. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
Step 2: Connect the controller to your computer
After you install the software, plug your Xbox 360 wired controller's USB connector into a USB 2.0 port on your computer.
Step 3: Test the controller
To test your Xbox 360 wired controller on your computer, follow these steps:
  1. On your computer, click Start, type Run, type joy.cpl, and then press ENTER.
  2. Select Xbox 360 Controller, and then click Properties.
  3. Test your Xbox 360 wired controller by pressing a button, pulling a trigger, or moving a stick on the controller. If the controller is functioning correctly, you will see the corresponding action light up in the application. If the application does not recognize your controller, see Troubleshoot your Xbox 360 controller for Windows.
Jan 06, 2014 | Microsoft Xbox 360 Controller
Game Mat as second player? how do I make it the first player
Turn off both controllers, then start the one you want to use as first, first. If that still fails, you can turn off both controllers then resync the first one using the sync button on the top of the controller and front panel of the xbox. If you are using a wired controller, you will most likely need to turn your xbox off then on, and connect the controller you want to use as first player, first.
Nov 15, 2013 | Konami Dance dance revolution bundle xbox...
My xbox 360 wired controller keeps on disconnecting its in the right way and i dont know wats wrong with it
There might be a problem with (a) the wire or (b) the actual controller. I would suggest testing the wire with another controller, if it works you know it's the actual controller that isn't working. If it still doesn't work after changing controller, you know it's the wire.
Another thing it might be is the USB port on your Xbox 360. Try changing it to another one if the other two suggestions don't work.
Dec 29, 2009 | Microsoft Xbox 360 Controller
Neither of my xBox 360 wireless controllers will sync with my 360 console. I have tried both contollers with a variaty of battery packs and they still wont sync but i have no problem with my wired...
Remove the batteries from both controllers, and unplug the Xbox for a minute. Now turn the Xbox on by the power button on the console, Install the batteries in your controllers, and hit the Console sync button first, then hit the little sync button on top of the controller.
If this does not work, you can purchase the wired charge pack that you must plug in to the USB port of the console to charge, and this will sync as your wired controller does. When it is synced unplug the wire from the controller and voila. Remember, the charger pack will look like this.
Good luck and be patient.
Dec 19, 2009 | Microsoft Xbox 360 Controller
My WireLess XBox 360 Controller wont connect to my XBox 360
i had the same problem, and is a easy fix, turn on your console, dont need the controller on, and hold the sync button for approx 30 seconds, then turn the console off, take out the power lead from the console and then remove it from your mains, wait about 1-2 minuts then plug it up and switch on the console, first sync the xbox then the controller, and this should work, if it dosent try xbox support their number is on
May 30, 2009 | Microsoft Xbox 360 Controller
Xbox 360 controller one wireless two wired
The port on the XBox has gone bad or there is dirt or something in the port. Use compressed air to blow out the port and see if it helps. If not the unit needs repair.,, try this out and see...
thank u rate me
Feb 10, 2009 | Microsoft Xbox 360 Controller
Wireless controller position
Try this:
Under heading "How can I change the screen positions for my wireless controllers?"
To reset the screen configuration for an Xbox 360 Wireless Controller:
  1. Turn off your Xbox 360 console and any connected Xbox 360 wireless controllers.
    (To turn off your wireless controller, power down the system and wait for the lights around the controller's Xbox Guide button to disappear.)
  2. Manually turn on your Xbox 360—don't use your controller's Xbox Guide button.
  3. Press the connect button on the front of your console. This is the small button just to the right of (or below, if your console is on its side) the port for Memory Unit B. The lights around the console's power button will flash as the console searches for a wireless controller.
  4. Press and hold the Xbox Guide button to turn on the wireless controller that you want to assign to slot one.
  5. Once the controller is on and the lights are still circling the power button on the console, press your controller's connect button, located just to the right of the charge port.
    When the lights on your controller stop spinning, the wireless controller is configured to slot one and the upper-left quadrant light will glow.
  6. Select the controller you want in slot two and repeat steps 4 and 5. You can configure up to four wireless controllers.
Sep 01, 2008 | Microsoft Xbox 360 Controller
XB360 Screen colour changes and then disappears
Could possible be your television.
Or maybe your Xbox is overheating.
Try placing your Xbox in a cool spot, direct a fan at it, etc.
Or try getting a new TV or Xbox.
Jun 29, 2008 | Microsoft Xbox 360 Console
Play regular Xbox games on Xbox 360 play ?
Yes the Xbox 360 can play regular XBOX games so dont worry. You can check for more info on the xbox website.
Dec 07, 2005 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Controller Logo
12,712 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
