Question about Nikon N55 35mm SLR Camera
My camera wont stay on?
I have brand new batteries, new film, but my camera wont power up. More confusing, I can put in a new set of batteries, take one roll of film and then the camera dies yet again, someone help!!
ice man
  • 68 Answers
SOURCE: Premature Film Rewinding
the only thing that I could think of when I read your situation is, that you might not be using a DX coated films. see, the camera reads the bar code on the film and maybe it is not the same program. check the camear manual and make sure you are using the same kind of the suggested film in the manual. good luck
Posted on Apr 13, 2007
SOURCE: nikon n75 problem loading film
I have (had) the same problem. I came onto this site to find out what I can do to fix it. It didn't help. I got pissed and almost threw the camera away. So I decided to get a little rough with the camera, (i normally wouldn't do this but i was going to throw it away).
I loaded the film like normal but before I closed the back I manually wound the film around the opposite spool. I guess I fooled the camera into thinking it had already wound the film.
When I closed the back of the camera everything worked fine.
I then snapped off the pics the camera said were left.
After this first role, I loaded the next role like normal. The camera worked like a charm!
By the way...the mirror dropped back down when I manually wound the film around the spool.
I hope this works...if it doesn't make any sense feel free to email me with any questions..
amasseur at gmail dot com
Posted on Feb 09, 2008
  • 667 Answers
SOURCE: Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Posted on Apr 27, 2008
Agent Allan
  • 480 Answers
SOURCE: problem in camera or film roll??
Hey msenile,
It is possible that each frame would have image data imprinted without and image being exposed. This could be caused by the shutter not opening while the camera still exposing the film internally with the image data recorded. It is unlikely that this bad film since the emulsion covers the entire surface of the film and if it were bad the image data would not be recorded either. Another cause of this but very unlikely is every frame was somehow extremely underexposed. This could happen if the camera is set to manual and the light level is low and the shutter speed is set to a fast speed and the aperture is set to a very small aperture. I hope this helps!
Go Ahead. Use Us.
Posted on Jul 24, 2008
SOURCE: N65 Film Winding problem
I have the same problem and I suspect that is the contact of the door.
Posted on Aug 27, 2008
  • 95 Answers
SOURCE: Loaded film blank
Chances are the film had quite a bit of curl to it (often a sign of old film) and it was not pulled over quite far enough during auto loading, or perhaps too far and it had too much slack that the take up reel never grabbed it to advance it thru. You're not the first one this has happened to as the auto load is not as reliable as the older style where you had to load the film leader through a slot in the take up reel.
Posted on Dec 28, 2008
0 characters
1 Points
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
Brand new battery? Because I know for instance Canon ships some of their batteries fully discharged to minimize the risk of damage during shipping... If not, remove the battery and make sure the contact points on the door and in the bottom of the battery bay don't look twisted or damaged in any way.
Jul 12, 2011 | Minolta DYNAX 700Si AUTOFOCUS SLR CAMERA...
I have a 35mm nikon camera. I've changed the batteries but the film won't load. how can i load the film?
Here is what to look at: Custom Function number 8, "Auto film load when back is closed", default setting is 1 disabled on 0 it is enabled. If you have the manual for the F80 (same as N80) look on page 21 and page 72 and 73.If that is not the issue check the following: With the new batteries does the camera turn on, Can you focus, does the LCD light up? All that will let you know if you are getting power to the camera. If the answer is yes then the film should load so now check the inside of the camera back. Does it have the pressure are and roller next to the hinge. If that is missing then when you pull the film to the red dot, close the camera back there is nothing to put pressure on the film for it to load.
Aug 06, 2010 | Nikon F80 35mm Film Camera
Powers on, wont load film, beeps constantly, Can't select a mode,
I had a similar problem today with my camera. I'm not an expert on Cannon cameras or any cameras for that matter, but this is what I did to fix the problem.
I removed the bottom cover(has 6 screws i believe) carefully sliding the cover up starting near the battery cover. Holding the camera still I checked what gears I could to make sure they were free, but one small gear that moves up and down was stuck. I applied a very small amount of force to the gear to free it, reattached the cover and all the screws, and BAM! I was back to taking pictures.
Hopes this helps.
p.s if you can't find one of the screws its under the battery cover flap :).
Apr 07, 2010 | Canon T70 35mm SLR Camera
Film won't load.
check batteries, if they are old substitute with known good batteries. One of batteries may be problem test individually under load test! . good luck
Aug 27, 2009 | Canon T70 35mm SLR Camera
Pentax A3000 frame advance jammed
There could be a number of causes.
First make sure that the replacement batteries are up to it. Ie one's marketed for camera use. Others often cannot supply the current required by the motors. (Electric motors require most current just as they start, and so it may not do anthyhing at all.) Then check the battery contacts are clean. Much the same reason applies, dirty contacts cam prevent the batteries from supplying enough current.
One more simple possibility is that it does not know the battery door is closed. This may be detected by a protrusion in the film door edge operating a contact in the loctaing groove, or contacts in the door latch. There may be more than one!
It is also possible that the camera is detecting an impossible film. DX coded film uses the contacts inside the film chamber to read the film speed from unpainted sections of the film cassette. It is just possible that a dirty contact or a scratch in the paint is telling the camera that the film is a speed it cannot handle, or is just confusing it with a nonesense code!
Outside these there are a number of possibilites which will require internal investigation. You can try these camera repair pages for tips on repairing your own camera.
Jan 22, 2009 | Pentax ME Super 35mm SLR Camera
Loading film in my vintage!
The "magic needles" while making the camera easy to load are about as intuitive as a dead skunk, I had a similar confusion when I got an ME Super. Put the film can in the left side of the camera back (the side with the little thing sticking out is the bottom, it looks upside down this way, but that is correct). Next push the film winder down, this will semi-lock the can into place. Now pull the film-lead across the camera and push it down between some of the white "magic needles on the opposite spool(push it in a bit so that it will stay). Next advance the lever; release the shutter. If the spool starts to turn you are doing it right. Now close the door and continue advancing and clicking until the little frame number window on top reads 1.
May 19, 2008 | Pentax ME Super 35mm SLR Camera
Pentax zx 50 35mm slr
Others here have suggested the problem lays with the plastic gear on the advancing motor beside the mirror.
This might cost $100 or so...?
Oct 22, 2007 | Pentax ZX-50 35mm SLR Camera
Nikon N55 35mm SLR Camera Logo
24 people viewed this question
Top Nikon 35mm SLR Cameras Experts
Ric Donato
Bart Pulverman
Are you a Nikon 35mm SLR Camera Expert? Answer questions, earn points and help others
