Question about Compaq Presario 1230 Notebook
I need the CPU dip switch settings/Labels for a n old Efio! A5000
I am running at 800MHz, looking to up it to 850 or 933 as those are the other CPUs I have onhand.
Will the Intel Core 2 Duo P8700 cpu/processor work with the Dell Inspiron 1420 laptop? I have already tried it and it wouldn't work and I'm wondering if I have to do anything extra for it to work.
The 1420 uses T-series CPUs with a front side bus (FSB) of 800MHz. The P-Series CPUs use a 1033MHz FSB and are not compatible with the unit. You need to stick to the T-series to stay compatible.
Jul 09, 2016 | Dell Computers & Internet
How do I get the Athlon 3200+ to run at 2.2 GHz?
you could look in the bois setting, in the advance section
cpu configuration, 32Bit data transfer, core performance boost, cpu smart fan calibratioon, control mode,shutdown temperature, plug and play OS, chipset menu,
look at software that allow you optimizes your system
glarysoft, glary utilities, DONT BUY ANY, LOOK FOR FREE ONES IF YOU FIND ONE THAN BUY IT.
Mar 31, 2015 | Computers & Internet
G614J processor upgrade
Hi there
the G614J is a Intel Celeron 450. which is a Socket LGA755 (this is the connector on the motherboard for a cpu, this is a deciding factor on what kind of cpu can be installed.)
Currently the LGA 755 socket is history, there are no cpus sold as NEW in the market that I can see, your only option is 2nd hand, like EBAY.com
I found a total of 7 cpus in ebay.
In my honest professional opinion it is not worth it to attempt to upgrade the cpu on your computer, consider buying a newer computer, used, or new.
I mean this stuff is trash,
http://www.ebay.com/itm/Lot-of-11-CPU-Intel-Pentium-4-2-8Ghz-521-LGA755-1M-800Mhz-SL9CG-/360517310223?pt=CPUs&hash=item53f081970f
that guy is selling 11 cpus for LGA775 socket for 50$ its few $ for one cpu.
Your current cpu has a front bus of 800MHZ you don't want to get anything lower than that, that is the only deal I found in ebay that wasn't slower than your current cpu.
I'd recommend you resell your old computer as is on ebay or similar and purchase a newer system.
Jan 19, 2013 | Dell Inspiron 530 Desktop Computer
Sir my motherboard is ASUS A7V266-mx when it boot it always asks dip switch is incorect and f1 to continue or del to go bios i dont understsnd what is the problem
dip switches are little switchs physically on the motherboard.
they replaced the jumpers which were found on older motherboards .
it needs to be adjusted depending on the cpu you are running .
and the front speed bus capabilites of you cpu and motherboard.
 newer motherboards allow alittle bit of tweaking the speeds and settings from the bios .try that is you are confident you know what you are doing
also referred to as multipliers. if none of the above means anything to you or is out of your understanding then you need to take your pc to a computer shop and have them adjust the settings on your dip switch .
somebody may hae configured it to run faster than is reccomended also known as over clocking ..
you may be risking your cpu and motherboard if you continue to use your comp .
Aug 02, 2010 | ASUS A7V266-C (A7V266-C W/A) Motherboard
I have bought a PIII 1Ghz CPU to replace my armada 110 Celeron 700MHZ CPU, Sometimes it works well for about an hour then just turn itself off, other times only lasted a few minutes. I've noticed that the...
With out knowing your motherboard it's a guess. However you can look at the link below. Then scroll to the bottom of the page. Your SL52R should be the 4th cpu from the bottom of the list. It doesn't look likely and it definitely runs hotter. http://www.cpu-upgrade.com/CPUs/Intel/Pentium_III/RB80526PY700256.html
May 30, 2017 | Compaq Armada 110 Notebook
CPU can not run on it's max freq.
If this is the bluetooth edition, then go here and have a look at the bottom of the page at the dim switch possitioning:
http://www.msicomputer.com/NB/product_spec.asp?model=MS-1012_(Bluetooth_Edition)
regards
Dec 22, 2008 | MSI MS-1012 Notebook
Motherboard
2.2Ghz should be the fastest for your motherboard, also the cpus FSB is MAX 400Mhz
the socket is S478
only old cpus work in your motherboard new and currently being sold, core 2 duo family prosessors wont work. they all have fsb 667 or higher and your motherboard only supports up to 400fsb
here is the best cpu for your pc
http://cgi.ebay.com/Intel-P4-2-2-Ghz-CPU-400-512-478-Socket-Northwood-SL6PL_W0QQitemZ260222969857QQihZ016QQcategoryZ14293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I would recommend a whole new system.
Apr 05, 2008 | Computers & Internet
T21 Processor Running at 624MHz
Run more programs.. Newer laptop cpus throttle back when not needed. If you want to run notepad at full speed, see if you can set the power saver options for full performance.
Feb 13, 2008 | Lenovo ThinkPad T21 2647 Notebook
Asus P3V4X/S370-133/Tualatin 1.2Ghz
It turns out that while the BIOS will not appear to recognize the Pentium 3 1.4GHz Tualatin CPU (SL6BY) in my Asus P3V4X motherboard, Windows XP does! I apologize for my delay in posting this.
I have five extra SL6BY processors that I'd like to sell if anyone is interested. I need to make some money to upgrade the memory in this antique to 2GB (turns out that low density 512MB RAM does work in the P3V4X, by the way).
Thanks,
Eric
Nov 22, 2007 | ASUS (S370L) Processor Board
Compaq Presario 1230 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
