Question about Mintek DTV-263 26 in. LCD Television
Tv not responding to remote or on product controlls
Seems locked. can not turn up or down, can not access dvd that is in machine...can't access the menu.
  • majonchobeac Jan 04, 2009
    tv not responding to remote, no volume adjusting, dvd player not responding.
  • jesseb832 Jan 25, 2009
    I have a 32" and have the same problem. The remote will not work.
    It did for a short period when I would put band new batteries in the romte but after a while that no longer worked.
    Any one have the code for a new Universal remote? If it is just the remote that could be replaced if you had the code.
    Thanks anyone who can help.
    jesseb@jesseb.com
4 Suggested Answers
  • 3422 Answers
SOURCE: mintek dtv-265-d tv &dvd
Can you tell me which remote you have so that i can give you the codes for it.
Or is the problem that your remote control is not working?
Waiting for your reply..
Posted on Feb 22, 2008
robotek
  • 1512 Answers
Hi there, are you having trouble with the set being "locked" Try turning it off at the wall for 30 mins and turn it back on.
We may need more information to help you sort this one out.
minteker
  • 52 Answers
SOURCE: Lost remote for Mintek TV-DVD combo
hey, had the same problem.
found one on ebay for $20 shipped.
also heard that the "Kameleon" Universal remote, from radioshack, will work with it.
The remote is the RC-600 (atleast for my DTV-265), and here's where I got it on ebay:
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&rd=1&item=360029014984&ssPageName=STRK:MEWN:IT&ih=023
Posted on Mar 11, 2008
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
Mintek dtv-265-d tv &dvd
Feb 22, 2008 | Mintek DTV-320 32 in. LCD Television
How to clear remote so I can program it again
Link to the manual
http://audiovox2.info/docs/rca_acc/man/D770_DOC_OM.PDF
Problem: The remote is not
performing commands properly.
• You must put the remote in the
correct mode by pressing the
corresponding component key (TV,
VCR, DVD, SAT, AUX1, AUX2) so
the remote knows which component
you want to operate.
• Make sure the component is “ready”
(e.g., DVD player has disc loaded;
VCR has tape loaded, etc.).
• You may have pressed an invalid
key for the mode the remote is in
(e.g., the RECORD key only works
in VCR Mode).
• If you are trying to turn on an RCA,
GE or PROSCAN component, press
the component key (TV, VCR, DVD,
SAT, AUX1, AUX2) instead of the
ON·OFF key.
• If you’re trying to change channels,
try pressing the OK key after
entering the channel number as this
is a requirement of certain models
and brands.
*There is a possibility that a
programmed code may only be able
to control some of your component
features (e.g., only turns a
component on and off). Follow the
steps provided for programming the
remote (See Programming sections
on pages 5–7). If the component can
be turned on and off, make sure you
press the CH+/CH- key to see if the
component responds. If not, try the
next code from the list.
Good Luck :)
PLEASE rate my solution
Dec 18, 2009 | RCA DIRECTV Satellite Remote Control
I have a Mitsubishi VS-45605 projection TV and a Philips DVD player model DVP3962/37. Can anyone help me figure out how to program the remote to control the DVD player? I only have the original remote for...
I've got the same tv and...I've still got the manual!;-)
Programming the Remote to control other audio and video products:
  1. Move the slide switch at the top of the remote to select the a/v product you want to control (in this case, DVD).
  2. Press and hold the Power button so that it stays down when you enter the code.
  3. Enter the code for the equipment. Release the Power button
  4. Point the remote at the equipment and press the Power button. If the equipment respondes, you're done. If not, and you have more codes that apply to that equipment, go back the step 2 and try the next number.
If none of the numbers work, I'm afraid you might be out of luck.
Oct 20, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Samsung DVD (1500) Remote problem.
Try to reset the blu ray player's remote control.
Remove the batteries and hold down the POWER button on it for 30 seconds.
Then replace the batteries with fresh ones
Jul 03, 2009 | Samsung BD-P1500 Blu-Ray Player
New Sony DVDVCR RDR-VX560 seems to be locked up
Problem was solved by Holding down the "ENTER" button for no less than 10 seconds and after releasing it press "SYSTEM MENU". This will take you to the setup screen on your TV.
where all settings can be made from there by following the on screen directions.
Jun 22, 2009 | Sony RDR-VX515 DVD Recorder/VCR
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Mintek DTV-263 26 in. LCD Television Logo
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
