Not turning on
I have put together a pc at home using a Gigabyte GA-VM800PMC m/b, E2200 processor and 1Gb DDR2 667 memory. I have connected all hardware. turn it on and there is no signal going to the monitor. I don't get the traditional beep when u first push the on button and the HDD light is solid on all the time. help??
  • pega10 Dec 31, 2008
    Have changed memory to ddr2 533. still same problem. i have removed memory to see if i get an error beep, but don't even get that.
  • 948 Answers
You have no signal going to the monitor because your system is not passing the POST (power on self test). This particular board only supports DDR2 533, 667 won't work according to
Posted on Dec 31, 2008
  • Dick
    Dick Dec 31, 2008
    According to the link above, the board does not support an E2200 processor either. E2220 and 2180 are listed, but no 2200.
The Gigabyte mainboard you have uses DDR333, PC2700 RAM memory.
Your model GA-81845GVM-RZ has 2-slots and each slot can have up to a 1GB of memory, therefore you can have 2GB total RAM memory on this model mainboard.
I recommend mainstream, reliable pair of 1gb each memory modules such as Crucial.
Good Luck
Aug 31, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
What kind of RAM memory uses this motherboard
Gigabyte GA-5SMM - motherboard - micro ATX - Socket 7 - SiS530 specifications
  • General
  • Product Type Motherboard - Micro ATX
  • Cache Memory L2 cache - 512.0 KB
  • Chipset Type SiS530/5595
  • Max Bus Speed 100.0 MHz
  • Processor Socket Socket 7
  • Compatible Processors 6X86 , Cyrix MII , WinChip 2 , WinChip C6 , K6-III
  • Memory
  • Max Supported Memory 256.0 MB
  • Supported RAM Technology SDRAM
  • Supported RAM Integrity Check ECC
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 x PCI - Socket 7 , 3.0 x Processor - DIMM 168-pin , 3.0 x ISA , 2.0 x Memory
  • Storage Interfaces ATA-66 - connector(s): 2 x 40pin IDC
  • hope this helps
Aug 13, 2011 | Gigabyte GA-5SMM Motherboard
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
Have more questions concerning this, or comments, please post in a Comment.
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
I want drivers of ga-vm800pmc vga ,via,s3g from where idownload
You can download all the required drivers for your Gigabyte GA-VM800PMC Motherboard from the
following link.
Nov 04, 2010 | Gigabyte GA-VM800PMC Motherboard
Gigabyte GA-8VM800PMD-775 @ 1.5gb memory
This is the website link for your board on gigabyte website. Suggest you have a faulty piece of ram or a clock speed miss-match. your board supports up to 2gb of memory.Try also reseating the memory. Let me know how you get on? chris
Jun 06, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
Not turning on
I find if you don't hear a beep...then the RAM could be faulty or wrong values.
Some Ram uses 2 RAM slots to boot.Hope this helps.
Dec 31, 2008 | Intel Motherboard
Uppgrade of processor!
Either there is a problem with the physical fitting of the processor, or the motherboard is not equipped to handle said processor, even with a bios revision.
Sep 27, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
