Question about Jenn-Air JGC8536 Gas Cooktop
Burner fails to ignite
One of my burners on my gas cooktop fails to ignite. It makes the usual clicking sound and I can smell gas coming out but nothing happens. If I use a match it goes on. I have tried cleaning it....but it didn't seem to be dirty in the first place...to no avail. I don't think it is wet either because I left it over night so it should have been dry. But it still does not ignite
  • Maria DeAngelis May 22, 2007
    I have found that the little igniter has a large chip in it. I think that might be the problem. Does anyone know how to go about replacing it? Do I just have to purchase that little piece or the entire assembly?
  • donnamc Jul 14, 2008
    Both burners in the front will not light unless I do it manually. I can see where the igniter on the one on the right is chipped. Can't see that on the one on the left. I see the sparks from the igniter going all around but never hitting the target.
I have this cooktop and it is hands-down the worst. That clicking sound is the spark missing the mark because of a crack or chip in the ceramic igniter. Damage is caused by the ceramic heating too quickly. Especially when the house is cooler in winter, or in air conditioning. I had a Jenn Air repair guy in to replace them before the warranty ran out and he said this happens with every single one of these models with the ceramic igniter. Also, one of the knobs on the front by the medium burner got so hot it melted. He gave us a new one. He had a whole box of them in his truck! He told us the design was inferior and that Jenn Air uses a different igniter for higher end models because of this problem, but won't re-engineer the lower end units because it's cost prohibitive. Even with the repairs they cover for the first year, they recoup in charging for service the second year, than profit on the repair and/or replacement charges for the parts every year after that. All the parts sold are OEM--no after markets, so, at roughly $27 a pop for each igniter, they make out pretty good. Oh, and the burner knob is melted again. What a bunch of scamsters. I will never give them my money again and am shopping for a new cooktop. I left a good review at bizrate for this cooktop.
Posted on Nov 23, 2007
  • jb_lord Jan 06, 2011
    We also have had both of these problems with this cooktop. It is a stupid design. We've replaced the melted knob twice already in less than 3 years. The first time we paid about $30 for the JennAir knob not realizing we could just get a pack of 4 generic "universal" knobs for about $12. The igniter to the front burner started not working sporadically after the warranty ran out and now is totally broken and needs to be replaced. A very inferior product.
    Problem Solver:
  • 11 Answers
Is the burner that won't ignite the left front?
Posted on May 20, 2007
It could possibly be that the ignition battery has gone flat. (Am assuming it runs on batt rather than main switch, as mine does)
On a 4 burner Gas cooktop - all 4 burners get gas but why does the igniter only work with the front 2?
Usually that's caused by clogged holes in the burners. I clean it out using a toothpick.
May 02, 2015 | Jenn-Air Cooktops
Cooktop burner do not ihnite
Hi hgodoy2 - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Nov 24, 2012 | Frigidaire 36 in.GLGC36S9E Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Gas burners lit, but electronic ignition still clicks
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
fsggfs
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Gas burner not lighting
make sure the burner ports are not clogged. and the caps are properly positioned. clean ports with a wire or a straightened paper clip if clogged.
make sure the igniters are clean and dry
Aug 03, 2008 | Thermador 31 in. SGS304Z Gas Cooktop
Burner clicks a long time before igniting you can smell the gas
Not sure about what part 1 is about. #2 indicates a failing ignitor gap or a bad gas mix. Get professional assistance.
Jun 13, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Gas cooktop BOOM
Gas is taking too long to ignite. Make sure the burner rings are installed properly. They have grooves that need to line up. Also make sure all the holes are clean.
Apr 03, 2008 | Cooktops
Jenn-Air JGC8536 Gas Cooktop Logo
530 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
