Question about LG LS-K1830CL Cool Mini Split Air Conditioner
NEED REPLACEMENT FAN MOTOR FOR FEDDERS PORTABLE A/C
CANNOT LOCATE REPLACEMENT PART
  • 69 Answers
Here is a link that should help you. Steve
http://www.servallco.com/default.asp
Posted on Jan 02, 2009
I have a fedders window ac unit 110 model A6X06F2A works fine for about 10 mins the the fan stops
i would try to oil bearings on motor. that failing replace run capacitor. motor must be getting hot.
Aug 01, 2015 | Fedders Heating & Cooling
I have a fedders portable a/c unit and it works for five minutes and it then shuts down. The circuit braker does not trip and I plugged the unit on different locations with the same results. The unit has...
Thanks for your information that " The unit has very cold air".It's cut off by indoor coil sensor.
Reason for shut off in 5 minutes.(There are one or more reasons for the problem) Check as follows.
1. Evaporator coil,air filter and bower wheel full of dusty. Service your unit completely.
2. Check rpm of blower motor. If less rpm replace capacitor.
3.If all above is o.k and still problem means defective coil sensor. Replace it.
Hope, it's helpful?
Jan 19, 2011 | Fedders A6X05F2D Air Conditioner
Just brought home a fedders aep09d2b*b portable air conditioner. bought it used. it worked well there but when I plugged it in at home it is making a lot of fan noise - more noise the higher the fan...
If it was running fine before and you moved it and it's making noise, it sounds like something fell against the fan blades. The reason it sounds worse when you turn it up is that the fan is running fast. Grab a flashlight and check to see what might have fallen.
May 12, 2010 | Fedders A6P09D2B Portable Dual Hose Room...
Need to replace seized fan motor
Fan motor has nothing to do with the refrigerant portion.
May 12, 2009 | Fedders A6P09S2A Air Conditioner
Fan won't come on.
First shut the power off then pull the blower out and try to spin the wheel if it spins freely then check the capacitor look for any swelling or dents and unless you know how to check it out, some AC parts stores may check it for you, but a lot of people just replace it first before the motor (it costs less usually around $5.00) if it's ok then the motor is probably bad and would need to be replaced.
Apr 23, 2009 | Fedders A6P09S2A Air Conditioner
Fedders A3X06F2G window air conditioner fan does not spin
Fan motor is stuck or defective it might need replacement. Check for broken fan blades or obstruction.
Aug 24, 2008 | Fedders A6Q10F2B Q Chassis Room Air...
Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Feb 05, 2008 | Fedders A7DH65B2A Dehumidifier
Replacement fan
please check the of fan , no of blades and direction of flow & also if possible pic of fan . it can be easily avl in open mkt.
ravi
Jan 31, 2008 | Fedders A6P09S2A Air Conditioner
Drain pan fills quickly
Can you descibe where the unit is located and what climate you are in? Thanks
Aug 09, 2007 | Fedders A6P09S2A Air Conditioner
LG LS-K1830CL Cool Mini Split Air Conditioner Logo
128 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
