Question about Zanussi 23 in. ZKT651D Electric Cooktop
Zkt650D ELECTRIC COOKTOP
WHEN I TURN ON THE APPLIANCE I GET THE ERROR CODE F13. IT IS DISPALYED AS YOU LOOK AT IT ( TAKING THE 'O' AS THE COOKER TOP) AS: F O O 1 O O 3 pLEASE HELP? zANUSSI WANT £125 TO BE CALLED OUT??
  • Anonymous Oct 30, 2008
    Our cooktop gives the same error.
    There is nobody who can help us.
I have a prestige induction cooker and it shows E4 error how do I solve it in india ahd plz tell me the perfect input voltage for my induction
Try turning the electricity off for 30 sec,and back on.
always unplug electricity before attempting to repair on any electrical appliance
Sep 12, 2017 | Cooktops
Tip
Fault Codes Kitchen Aid cooktop
F03 One or more eyes permanently pressed. Recommend that the glas be cleaned and all objects removed.<br /> Unplug the unit for one minute the plug back in if the error still remains after returning power then you will need to replace the touch control module.<br /> <br /> F12 Electronic board and touch module communication error.Unplug the unit for a couple of minutes.Restore the power if the error return then you will need to replace the board connection cable between the touch control module and electronic control. if the error remains replac ethe electronic control board. If the error comes back again replace the the touch pad.<br /> <br /> F13 Internal CPU checksum error.Recommend you replace the touch control module.<br /> <br /> F22 Key sensitivity problem.Turn power off to unit for a few minutes,if the error returns after power is restored replace the touch control module<br /> <br /> F36 Temperature probe hardware error.Recommend that you replace the touch control module.
on Jan 02, 2011 | KitchenAid 36 in. KECC568 Electric Cooktop
Displays error 40. Why won't it turn on?
Hi Dolores, I understand that your cooktop will not turn on after receiving an error code "40". Usually this error code can indicate a communication error between the Induction Module, Relay Board, and Control Board. I would also recommend doing a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 01, 2015 | Electrolux 36" Electric Hybrid Induction...
Electric range
Good Morning Kent, thank you for allowing me to assist you!
Typically error code F1 on your Frigidaire appliance indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Feb 05, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
E 3 error what does this indicate?
Error Code: E3Reason: The voltage is higher (140V-160V)for 3 secondsSource: Induction Cooker Error Codes Explained
Aug 20, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
Hi, I have a creda colonial range cooker. Yesterday I was using the fan oven and it tripped a fuse in the main fusebok of our house. I reset the fuse and now the 2 oveens wont work. The lights come on and...
All electrical appliance has a safety fuse located somewhere in the interior, most of the time it can be replaced.
Sep 13, 2017 | Creda Colonial 42352 23 in. Electric...
Zanussi 23 in. ZKT651D Electric Cooktop Logo
Top Zanussi Cooktops Experts
fyigen
Brian Coughlan
Tom Chichester
Are you a Zanussi Cooktop Expert? Answer questions, earn points and help others
