2003 Ford Expedition Eddie Bauer DVD player won't read discs
I have a 2003 ford expedition with roof mounted dvd player that won't read any discs. Says "Disc Read Error". How can I diagnose or fix?
  • 1 more comment
  • tjcinch Jan 10, 2009
    My 2003 Explorer has the same problem. It won't recognize disc?? help
  • Anonymous Jan 28, 2009
    I have a 2008 Limited Expedition and have had the same problem for about 3 weeks.
  • middle_l Mar 11, 2009
    I have the same problem and have had since we bought the truck 3 years ago. Some discs it will read just fine, and some it won't. HELP!!
  • 244 Answers
SOURCE: Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Posted on Nov 17, 2007
  • 55 Answers
SOURCE: Player won't read Dvd
try very carefully to clean the lazer lens with some alcohol...if this fail you should visit the repair shop
Posted on Nov 18, 2007
SOURCE: DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
Posted on Feb 14, 2008
SOURCE: Insignia roof mount DVD player for car wont read disc
My Necvox RE9269 Dvd Player Starts And Then Stops In A Moment Then Displays The Message 'NO DISC' Can Anyone Help Please
Posted on Jul 03, 2008
VOTIT
  • 2071 Answers
SOURCE: My dvd player Samsung DVD-R135 will not read any disc
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Sep 06, 2008
Ford Expedition VIN Style
get in touch with your local ford dealer and give them the vin #
May 27, 2015 | 2000 Ford Expedition Eddie Bauer
How do I fix the DVD player when it keeps reading "Bad Disc" on the LCD?
check that the disc used is formatted right firstly and is compatible with the dvd unit.
May 24, 2014 | 2006 Ford Expedition Eddie Bauer
Hello, I just purchased a 2004 ford expedition. The overhead dvd player will only show a blue scren after the dv is inserted.. Please help
may need clened because its not recognising a disc.. get a can of dvd spray with the tube on it(like dusting spray) and insert the tube and inch or so inside the slot..spray short bursts of spray into the unit..wait a minute or so and retry..repost findings..
Dec 09, 2013 | 2004 Ford Expedition Eddie Bauer
1998 Ford Expedition Eddie Bauer SERVICE ENGINE SOON light
Take the vehicle to any local auto parts store that will read the codes. WRITE THEM DOWN, and report back here for further help.
Dec 21, 2009 | 1998 Ford Expedition
Location of Shift Solenoid in 1999 Ford Expedition Eddie Bauer?
They are round "cans" with wires attached. You should have SSA, SSB, SSC, Torque converter and Pressure Control solenoids. They control pressures and have no mechanical linkage.
Oct 17, 2009 | 1998 Ford Expedition
Delphi dvd wont eject or load
You will either have to replace the unit, or have it sent in to ford to have it repaired
Sep 14, 2009 | 2004 Ford Expedition
Electrical
will it work while in the ignition and running?
Aug 24, 2008 | 2001 Ford Expedition
Televison & Video Logo
1,084 people viewed this question
Top Televison & Video Experts
Electro Med Services...
