Question about Sony Playstation 3 (PS3) Console
Playing on a regular TV.
I played my playstation on a regular tv for a long time, then I started to play it in HDMI. But now when I try playing it back in normal TV, it doesnt work.
    Problem Solver:
  • 9 Answers
Ensure you have returned the PS3 video output system setting to 480i vs the 720/1080 setting. Regular TV will give you a black screen at the higher resolutions.
Posted on Dec 31, 2008
Hdmi ports not working
reset your playstation 3 video setting
Reset Video Output
If you are changing cables or cannot see an image on the screen, you may need to reset the video output to default settings. To reset the video output:
  1. While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
  2. The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 21, 2013 | Sharp AQUOS LC-40LE830U 40" LCD LED HDTV
I am having issues with my RCA Scenium D52W135D (playstation 3 connection). Recently, I have been having a very specific problem with this combo. I have it connected using HDMI to a Pioneer receiver...
Had the same problem. With mine the other day you probably moved your Playstation 3 too another tv and set your 1080i,720,480 to high deaf on settings in Playstation. You have to change them back to automatic that TV says HDTV but it only plays Playstation 3 on 480 checked in settings of Playstation. Played mine for 4 years on that TV moved and got a 3d wifi then dad got him one And was going to trash that RCA but I told him I would take it for now too keep from buying another TV at this time got it in my new home wouldn't play video but it. would sound tried different cables but still now change. But remembered i changed all of my settings over when I got 3D TV. Playstation 3 hadn't been on know other TV. Since I owned it but that RCA now won't work then came to me last night and playing it on both TVs but you have to change the settings on it before moving it or you cant see the screen to fix it do that guarantee it will fix it. Like you said everything else works PS 1,PS 2,DVD, cable,but PS 3 won't its the settings in theme,and audio.
Nov 10, 2012 | RCA D52W135D 52 in. TV/DVD Combo
I played my ps3 for the first time using my old tv(no hdmi slot)..then i try to play at my second tv (hdmi tv)& surely can play successfully.. but the problem occured when i played for the third time...
Hello,with the unit turned off press and hold down the power button till you hear the second beep then let go,about 8 seconds later video should return to the older tv.
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
Just played a blu ray film, and it looks a little washed out, how can i improve it. I am playing it via HDMI lead to the TV, but the tv isn't hd ready.
Try using the regular A/V cable, its not going to be in HD quality but it might clear the washed out view, and you might get a better picture even tho not in high definition
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
Blue rays not playing and screen says no signal
This is blue ray lens failure. this optical Assembly has two separate reading lenses. there is one designated for Cd audio and CD_ROM reading and, the other is blue ray compatible. the blue ray lens in inoperable at this point. you will need to replace this lens assembly.
May 27, 2009 | Sony Playstation 3 (PS3) Console
Cant play my xbox 360 on my 22 inch Insignia tv
Is the TV an High Definition TV?
If it's not an HDMI compatible tv them you will need a regular audio video cable for your XBOX 360
you cn get them all day on ebay or at any store.
May 25, 2009 | Insignia 22 in. Widescreen Flat-Panel LCD...
I have been playing my playstation 3 on a regular Hd tv and it worked fine but now it wont connect to my Protron (HDMI) tv with my HDMI cable.
you have to reset the video setting and it will work again Hdmi is different on each tv so you have set this up again ok let's do this with the unit off turn the main switch on the back of the unit connect your Hdmi cable to your tv now place your finger on the front on/off switch keep your finger there ok now turn the mainswitch on the back of the unit the playstation turns on but don't remove your finget yet wait about 4 seconds or until your heard another bip (not the one when the playstation turns on) once you heard this bip remove your finger before the playstation turns off if you let it turn off try again all of this but if you remove your finger on time just wait few more seconds and bingo you have picture again using Hdmi
Mar 10, 2009 | Sony PlayStation® 3 (80GB) Console
Playstation 3 Does not display on TV using HDMI or regular video
This happened to me a few years back so I apologize if it's not 100% accurate. If you can get it to work on another TV, go ahead and connect it to that, and go in to the settings to select the video input. If it's connected through an HDMI cable, then it will probably be set to HDMI. Change the input here to whatever cable you used in the living room. You will have to power it off at this stage, but when you connect to the other TV it should work.
Mar 14, 2017 | Sony Playstation 3 (PS3) Console
Screen flickers when I play a BD movie on my PS3
Does it do this with all Blu-Ray movies?
Have you tried a different HDMI cable?
Jun 18, 2017 | Sony Playstation 3 (PS3) Console
Ps3 hdmi-av
i currently have the exact same problem...i always play HDMI but i went home from college for thanksgiving and wanted to play on a regular AV jack TV, hooked up, and have no picture whatsoever...and i think it's because of the settings on the PS3 since it's set to send out an HD signal...Well i found this straight from Playstation3.com, on the support/troubleshooting section
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution."
Hope it helps =)
Nov 17, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
81 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
