Kenwood KDC-MP5028 CD Player Logo
Posted on Dec 31, 2008
Kenwood kdc-mp5028 cd player
Dont have code.have remote(rc-527) tried entering kcar code nothing is hapening! remote doesnt seem to effect stereo at all,am i doing wrong?
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Dec 31, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
2890
Points
20
Recently had same problem when i brought the radio to the shop i brought it to him with all the wires in the back trimed so no copper was showing when i got it back the right rear wires had been stripped along with power and ground now as far to what happens behind the sences i dont know but i would guess they merge thee two and power it on and wait because it took they 4 hours to do mine
2answers
Ulock code kdc-mp5028
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
by Robotek
hope this helps...
tip
Thanks Robotek. Here is what worked for me- the differences is in how you enter...
Hi there, there is a standard procedure we use to bypass the code when we have the gear on the test bench for repair. Try this and it should sort out your problem
You need the remote control to do this, if you don't have one, then you may need to go to a KENWOOD agent and get them to clear the code for you, or purchase one for your use.
KENWOOD KDC SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
Type 2
Type 3
The security is canceled and the set enters the TUNER mode!
:) POSITIVE FEEDBACK :)
A FixYa rating would be fantastic for helping you out with this techo tip.:)
A FixYa vote is a great reward for the challenge of solving your problem
ask Robotek
Code for a kenwood kdc 319 cd player
i think the security code on most kenwoods is KCAR. you have to enter the code from the remote control though.
I have a mp5028 and it tells me 2 enter the code.
you will need a remote for this
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
6helpful
2answers
I need the Kenwood KDC-MP438U user manual
The Kenwood crack code is KCAR. Give that a try.
6helpful
2answers
Kenwood car stereo radio works but cd player want says code off any suggestions
tengo un carro con un stereo kenwood kdc -mpv7019 como lo puedo desbloquear
Car cd player code breaker
for your kdc-mp528 will work whith code KCAR entered from the remote
Type 1
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
5
5
Track Up
Track Up
Track Up
7
7
Track Up
i hope this works for you.
2helpful
UNLOCK SECURITY CODE
Type 1
Type 2
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Kenwood kdc-mp5028
Car remotes are not like universal TV remotes, you can not program them to work with a radio they were not designed to work with.
If this is the remote that came with the radio, you may just need a new battery.
I don't have the sevice info in front of me right now to tell you if this remote is compatible with your radio.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
