Question about Centrios EDW8020 DVD Recorder
Centrios dvdrw When I turn on my player the pictures spins. The picture and sound comes on the picture just spins, Horizontal lines all through the frame.
  • 3 more comments
  • Estimator333 Nov 23, 2007
    I have some VHS tapes I want to transfer onto DVD and am getting protection issues. The VHS tapes aren't purchased pre-recorded, just programs I have taped from cable.
    Any solutions?
  • livandbob Nov 24, 2007
    DVD picture comes on but spins. Can't find any button that helps.
  • Anonymous Dec 13, 2007
    picture spins
  • dewittw1 Dec 26, 2007
    Our Centrios EDW8020 "rolls" just like the old fashioned TVs used to do. Back then we'd use the "horizontal hold" control to stop the rolling. Any idea how I can stop this when my Centrios is trying to play a DVD?
    DeWitt
    dewittw@windstream.com
  • mathishd Mar 10, 2008
    My recorder does the same thing and the picture is in black and white. I tried through all the video hook-ups...any suggestions are appreciated...thank you very much...Roger Mathis
It worked wow thank you so much, i just pressed the n/p button on the remote, i am so happy i was actually thinking of buying a new one, but found this solution, thanks
Posted on Jul 26, 2007
Press the N/P button on the remote. I believe this switches between Pal (Europe) and NTSC (U.S.). Try again if it doesn't work at first.
Posted on Jun 08, 2007
    Genius:
  • 2,985 Answers
If you mean the TV picture rolls- this is a TV adustment or cable replacement requirement Contact the player and TV makers websites Tech Support for this.
Posted on May 17, 2007
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
36' toshiba with red screen and glowing horizontal lines.
Bad connections on red drive transistor on crt module. Resolder all connections on crt pcb.
Nov 25, 2011 | Televison & Video
5 year old panasonic viera LCD works great until tonight, screen turned into vertical and horizontal rainbows, can see vague picture behind all the lines like looking through thin black horizontal venetian...
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
No picture no sound just a whistling noise
maybe the flyback transformer or horizontal output ic
Jun 01, 2009 | RCA 27R411T 27" TV
Horizontal blue line
The intermittent horizontal line is cause by a loose solder connection in the vertical amplifier IC.
The IC is mounted on a heatsink nearby or around the flyback transformer.
The way to fix this failure is to add fresh solder where you see some brown spots on the circuitry that were cause by components getting hot.
Good Luck.
Jun 20, 2008 | Sharp 25R-S100 25" TV
Samsung TV stopped displaying picture
No picture but sound can mainly be of two problems, most of the times it is caused by a faulty vertical deflection ic, you can diagnose this by slightly increasing the screen voltage by turning the screen control on the LOT, a horizontal line will appear if the vertical ic is shot, and the other problem is the CRT base, but this is less common for shot base won't go off at once, it will show picture faded in the beginning. Now another problem could be the horizontal output transistor, if the tv has a high power sound output, the sound power supply will come from smps itself instead of from LOT, check that too, to confirm this, check if the CRT filament is glowing. Good luck.
Jan 17, 2008 | Televison & Video
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
Centrios EDW8020 DVD Recorder Logo
200 people viewed this question
Top Centrios Televison & Video Experts
Ron Oblinsky
Level 1 Expert
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Centrios Televison and Video Expert? Answer questions, earn points and help others
