Question about Memorex MLTD2622 26 in. LCD TV
Memorex HDTV no picture
I have sound, but no picture. I can change channel and adjust sound but no picture. The Memorex name comes up when I turn the set on but again no pictute
  • 5 more comments
  • Anonymous Jan 07, 2009
    same deal for me ... happend a few months ago and went away on it own...just happend again this morning
  • tschirgiger Jan 14, 2009
    Same problem, no picture and sometimes just sound..My TV is MLTD3222. I'll try covering it with a blanket, it doesn't get that cold here in Austin, TX, but it has been chilly the last few nights..
  • Anonymous Jan 17, 2009
    I have a 32 in. MLTD3222 same exact ptoblem..Sound but no picture it has happened 2X's in the last 4 months
  • Clay
    Clay Jan 26, 2009
    I have MLTD3222 exact same deal. Quick flash of "memorex" (which means "crappy-TV" in some other language), and then blank. Can not change inputs because I can not see display. I live in Florida and it is not a temperature issue. I hope mine goes away on its own also, but with all the same issues..does not look good. Get what you pay for I guess..it was super cheap at Target. Hope Memorex gets enough complaints to issue repair vouchers.
  • Anonymous Feb 05, 2009
    I have de same problem with my tv MLTD3222 not have picture only have sound.
  • dosdejulio Mar 21, 2009
    I own the memorex 32 tv/dvd combo and the same thing you have describe happened this morning. Tv comes on as usual with memorex logo then goes black with audio on. I have owned the television 8 months without a problem until today. I read some say that the cold can make this happen to the screen but its 70 degree today in my part of california, its been much colder a month or two ago and i had no issues. Im trying the blacket over the tv for 30 min advice before i start looking at talking to the memorex.
    ps i also got it at target and paid for the extended warrenty, i felt like a chump afterwards but now im glad i did.
  • Anonymous Apr 20, 2009
    Don't ask me how but the blanket worked for me too. April 19,2009 tv was new in september. I hope it is long term solution. let's see if it still works tomorrow.
I am going to assume that you have not already found the answer to this problem. It is actually pretty common for flat panel televisions in the winter to be too cold to turn on. What I did when faced with this problem on my 32 inch memorex was turn it on for 30 minutes while covered with a fleece blanket, than turn it off. When you turn it back on it should work...did for me!
Posted on Jan 08, 2009
I dont have a new solution, sorry. what i do have is good news, at least for me at this moment, about the advice or solusion given about. 45 min ago i tried the blanket over the tv and it worked, my memorex is up and running. I hope the same happens for all that have the same problum. thanks for the help.
Posted on Mar 21, 2009
My tv pop. i have no sound no picture. what's the problem. does anyone have a solution :(
Posted on May 24, 2010
Model #_LT52152, when turn on TV no sound, sometimes picture frozen and sometime cannot change channel. Help!
Sounds like a firmware corruption. Contact the authorized service centre for Mitsubishi. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Mitsubishi LT-52151 52 in. LCD HDTV
Memorex MLT1912: Signal only coming through on two channels
Did you try setting and finding the other missing channels manually?
Jan 03, 2008 | Televison & Video
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
The memorex brand icon comes on briefly when i turn on the set
Try the link.It may help.
http://www.devicemanuals.com/guide/Television/Memorex/Memorex-MT1134-13-Color-TV-with-front-A-V-jacks-T1RJMU5UTT.html
Jun 01, 2009 | Memorex Televison & Video
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Distrorted Picture on all Analog Channels, HDMI and PIP Picture is fine.
Sounds like a bad DLP chip and they will prob end up replacing the light engine in the set most people dont like replacing this part. Hopefully they get you up and running.
Jan 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Memorex tv programming
I am trying to start remote ucr3110B00 on memorex MT 1120A please help me.
Dec 08, 2007 | Memorex MT2206 TV
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Memorex MLTD2622 26 in. LCD TV Logo
1,412 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
