Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis Steam dryer runs but gets a F 40 code and stops. Just plugged it in to do my first load. Tried pulling out and checking lint in vent. It seemed to over heat the first time then sat a few minutes and I started it again to dry my towels. It counted down to 1 and stopped again without a signal that it was done.
  • Kathie Kresha
    Kathie Kresha Apr 01, 2009
    It did it again and had to have parts replaced. A sensor wire was not attached at the factory and then the board didn't work and after almost 3 weeks of a new dryer not working and waiting on parts they brought me the store model and it works fine. Not likely to do buisness with Sears again! It takes way too long to phone in for service and then 3 days is too long let alone 3 weeks on a new machine.
After just now calling the service center it seems that unplugging the machine for 30 seconds or so will reset the control panel. The F 40 code means the signal wasn't working in the machine and resetting it solved the problem. Kind of like when you have to unplug the computer sometimes.
Posted on Dec 31, 2008
My Kenmore Oasis gets the F 40 code does it need a new user Interface ? And if so is ther two circuit boards that I should replave at the same time?
Posted on Apr 01, 2009
Dryer turns on then stops in 5 seconds and flashes F40 code. shuts down
Check lint filter, check vent outlet at dryer, and continue on through vent checking for lint to the exit area of the vent. Keeping the vent lint free saves energy and reduces drying time.
Sep 06, 2015 | Kenmore Elite Oasis ST 7806 Dryer
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
The Kenmore Elite Oasis Steam Dryer - almost new - worked well last week. This week no power to dryer; 220volts is present to dryer. Any ideas?
You might want to take a look at the vent pipe for lint. If the exhaust thernistor detects high temps it shuts down the dryer. Bravos service manual (same as oasis)
Apr 29, 2011 | Kenmore 67082 Electric Dryer
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
Dryer stopped and said check lint screen
There is a lint screen,usually on top of the dryer, that pulls out to remove the lint,it is probably stopped up.
Mar 01, 2011 | Kenmore Elite Oasis ST 7809 Dryer
Dryer is working but will beep while running and continue to run. I clean lint trap after every load and have checked it.
underneath the lint trap there is a senor, you will need to clean all the lint out inside the dryer and the vent tube:
http://www.applianceaid.com/wpdryer_how-to.html
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite oasis dryer model #110.6708 will not operate. flashes f-40. what does f-40 mean?
F40 = thermal fuse blown.
If the fuse is OK the error points to a communication problem between the machine control board and motor control board (check connectors).
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
522 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
