Question about HP PSC 1610 All-In-One InkJet Printer
Foxpro dos programme not printingin usb printer laserjet cp1515
I have Foxpro 2.6 Dos application . I try to print the report in laser printer cp1515 and no print comeout. It is printing in lpt1 printer dot matrix,. What is the solution? Please help.
  • Anonymous Jan 11, 2009
    I have the same problem to print the report in laserprinter cp1515 and no print comeout. The print command is thro' Foxpro 2.6 programme on editor. It is printing in lpt1 printer dotmatrix,. What is the solution? Please help. Similarly while running the programme of Foxpro 2.6 it gives message as "Invalid database number
You can access your printer connected to USB port with loop back configuration and print from DOS.
Not only that, you can also print to a printer on the network
Try
Net use lpt1: \\Comp name\ printer name /persisten:yes
Posted on Jan 22, 2009
I am using dos based foxpro application in widows xp. when ever i take print from epson Fx 2175. the print job is paused at last line until i close the application. please rectify.clarify,...
Many DOS programs were designed to write directly to the printer's buffer, rather than to a spooler like more modern applications. It sounds like FoxPro is doing exactly that - and isn't designed to release the job until being completely closed.
Mar 06, 2011 | Epson FX 2170 Matrix Printer
Foxpro 2.5 Application can't direct print in xp cause in my print Dot Matrix with Epson LQ-2180 using USB to Pararel Port...
share the printer then search for your own computer and you should be able to open it and see the shared printer like. \\server\printer
then use net use command...
net use lpt2: \\server\printer /Persistent:yes
then tell foxpro to print out lpt2 and it will act like dos
you can add net use command to autoexec.bat or windows startup if you will do this often
Nov 08, 2009 | Electronics - Others
Tally Genicom Slow Printing in Foxpro Dos Program
change the connecting cable serial or parallel what you have it may help you.
Jun 15, 2009 | TallyGenicom 2280 Matrix Printer
How to print foxpro2.6 dos application to laser jet printer
THE CUSTOMER SHOULD TRY REINSTALLING THE DRIVERS,AND IF PROBLEM PESISTS HE SHOULD TAKE THE PRODUCT TO AN HP SUPPORT END.
Feb 06, 2009 | HP LaserJet 1020 Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Foxpro dos application exe obfuscation
you need the re-fox or fox shell
is works good
an from mexico
Jan 02, 2009 | Microsoft Visual FoxPro Professional...
What is the command for networking printer for foxpro in dos ?
you can do this thru printer maping
try this DOS command
net use LPT1 \\computer name\printer
Dec 15, 2008 | Computers & Internet
How to redirect lpt print to canon lbp-3000 printer
Here's what you need to do. ON the computer that you want to associate that LPT1 port, you need to know the name of the computer, and the share name of the printer. In this case, I am assuming you have the Canon LBP-3000 physically connected to this system running the FoxPro program.
Step one: Find the computer name. Click on START SETTINGS CONTROL PANEL. Double click SYSTEM. Click on the tab COMPUTER NAME and under FULL COMPUTER NAME, write down the name. Click OK to exit the window.
Step two: Click on START, SETTINGS CONTROL PANEL. Double click PRINTERS AND FAXES. Right click on the Canon LBP-3000 printer and click on SHARE. In the window that opens, click on SHARE THIS PRINTER and take note of the name in SHARE NAME: and write it down. Click on OK to share the printer and exit out of the wizard.
Step three: Click on START, RUN. Type CMD in the box and click OK. in the black window, type NET USE LPT1 \\COMPUTER NAME\SHARE NAME
Follow with RETURN or ENTER and you should be good.
Aug 04, 2008 | Canon LASER SHOT LBP-3000 Printer
Dos compatibility
yes intel 945 chipset is not proper work on Dos based programs.u can use foxpro for window
Jan 08, 2008 | Gigabyte GA-8IDXH Motherboard
HP PSC 1610 All-In-One InkJet Printer Logo
706 people viewed this question
Ben Johnson
