Question about Kenmore 98702 Stacked Washer/Dryer
Lid Switch Replacement-How do I get to it, etc ?
Kenmore 25842400
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
How can I order and replace the lid switch on a kenmore washer 110?
There are numerous videos on Youtube which will show you step by step how to replace the lid switch. Just type "Kenmore Lid Switch Replacement" in the Youtube search box
May 06, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
How do i replace the lid switch on a top load
Cut and paste this video link to show how to remove the cabinet for switch replacement.
Jan 01, 2010 | Kenmore Washing Machines
Kenmore 80 series washer, replaced lid switch already, will fill, wash (agitate) but stops before draining and spinning and will not run. Is the timer the next step for replacement? Model: 110.29852991
First check the continuity of the wires in the lid switch and the switch itself. Make a jumper wire to attach to the lid switch connector on the washer cabinet and set it to spin. If still no spin,replace the timer.
Aug 14, 2009 | Kenmore Washing Machines
The part that gets pushed down by the lever when the washing machine lid is closed broke off my older Kenmore Washing Machine. Can it be replaced or do I need a new washer?
Its the lid switch i think, of course you can get a replacement and fit it yourself. You need your model number, etc to look below.
Sites for spares:
Mar 13, 2009 | Kenmore 15864/15862 Top Load Washer
I have to replace the lid switch (which I now
soory but was unable to pull up a model number, ill assume that you have a top loading washer, in which case you can search you tube-- "kenmore washer repair" . theres videos as to how to remve the cabinet. easy to do once youve seen it
Mar 01, 2009 | Kenmore 24032\24036 Top Load Washer
This often appears to a more serious problem than it really is. The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at Just type in your COMPLETE model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 11 (part #3949238) and the lid strike will be listed as item number 20 (part #350733). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Oct 07, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
56 people viewed this question
Sal De
 Brian Main
Brian Main
