Question about Philips TS2546C 25" TV
HI MY PHILIPS 25INCH TUBE T.V ONLY GOES FROM CHANNELS 2 TO 42
I CAN GET IN TO THE MENU SCREEN SO HOW DO I GET ALL THE CHANNELS PROGRAMED.
  • most_ex Dec 31, 2008
    I DID THAT BUT I STILL CANT GET TO THE MENU SCREEN BY PRESSING VOLUME AND CHANNEL AT THE SAME TIME.
    THAT WORK THANK YOU BUT NOW I GET TO MENU SCREEN AND ALL I SEE ON THE LIST IS CC - SLEEP TIMER AND EXIT ON THE MENU SCREEN AND NO AUTO PROGRAMMED LIST.
  • 8,596 Answers
Either press menu on the Philips remote and go to autoprogram, or (if you have lost the remote), press volume - and channel - at the same time. When menu appears, use channel - to select autoprogram and volume - to select it.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
  • Corey Knoettgen
    Corey Knoettgen Dec 31, 2008
    Sorry, it is volume + and volume - at the same time on that model.
    -Tha Mp3 Doctor
  • Corey Knoettgen
    Oh fooey - that one was a business model - it will not work without the original green/master remote. You cannot simply order one, since only one was assigned per set. Looks like you might be stuck with chs. 2 to 42 - sorry.
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: HII HAVE A PHILIPS 25INCH TUBE T.V
Volume + and volume - at the same time will bring up the menu.
-Tha Mp3 Doctor
No sky no happy
Unplug from the main power and that should reset your sky box. If still no signal get the dish looked at by a tv aerial company.
Apr 07, 2017 | Philips Televison & Video
How to scan for new digital channels small Philips flat screen
From the menu you should see set up the cannel scan should be there.. If all else fails unplug the TV for a few minutes then plug it back in. It should ask if you want to set up the tv, Say yes and follow the steps.
Jun 16, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
-Tha Mp3 Doctor
Dec 31, 2008 | Philips TS2546C 25" TV
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
25 inch sanyo tv
If the horizontal lines going through the picture are fine white lines, then I would suspect the picture tube as having a heater to cathode short or some other problem. Since some sets have had a 3 year warranty on the picture tube, you may be lucky unless the labor to replace the tube is more than the set is worth. Sanyo is usually not a good name in consumer electronics anymore, so if you're looking for a replacement I would look elsewhere.
Mar 31, 2008 | JVC AV-32F704 32" TV
PHILIPS 50P8341 60 IN.
Check the other posts for convergence problems. This may be what you're experiencing. Have you tried bringing it in with multipoint convergence? It's under Menu -> Picture -> Manual Converge -> Multipoint Red and Multipoint Blue.
Dec 07, 2007 | Philips 60PP9202 60" Rear Projection...
Loss of programed channels
check philips website for a software upgrade. this is a consumer level repair and is pretty simple.
Oct 04, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
How do I remove on screen tutorial
first question... can you go through the tutorial?
Aug 01, 2006 | Philips Magnavox MT1931B 19" TV
Philips TS2546C 25" TV Logo
189 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
