Question about Dishwashers
Maytag jet clean dishwasher model WU304 leaks - outlet hose leaks
When the wash and rinse cycles are completing the hose under the housing sprays water. Does the hose need replacing or can it be repaired in any way?
    Scholar:
  • 140 Answers
If the hose has a hole in it you should replace it because it is worn out .Usually when these hoses leak you just need to tighten the clamp or reset the hose on the outlet.
Posted on Dec 31, 2008
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
Tip
How to troubleshoot your dishwasher
<span>Instructions</span> <ol> Dishwasher Does Not Run <li> <br /> Make sure the power is on, door is latched and controls are set properly.<br /> </li> <li> <br /> Look to see if the door switch, timer or selector switch are defective. Solve this problem by using a screwdriver to adjust the door latch's strike slightly.<br /> </li> <li> <br /> Confirm that the power cord is plugged into the electrical outlet under the sink (if applicable).<br /> </li> Dishwasher Won't Fill <li> <br /> Check your hot water supply stop valve under the sink. Turn it counter clockwise to ensure that it is open.<br /> </li> <li> <br /> Turn off the power and wait for your dishwasher to cool.<br /> </li> <li> <br /> Look inside for a float located at the base of the unit. Lift out the float device and clean around the tube. Rinse off the float and reattach it making sure it moves up and down freely.<br /> </li> Dishwasher Doesn't Drain <li>Remove the air gap cover (short chrome cylinder located at the back of your sink) and clean it using a wire.<br /> </li> <li> <br /> Check the drain hose for kinks and blockages.<br /> </li> <li> <br /> Shut off the power to your dishwasher and remove the strainer located at the base of the cabinet under the bottom spray arm. Scrub it clean then reattach it to the appliance.<br /> </li> Dishwasher Leaves Film on the Dishes <li> <br /> Add a rinse additive to your washing cycle and see if this solves the problem. In addition, do not pre-rinse your dishes prior to placing them into the dishwasher. Food particles allow the detergent and drying agents to work more effectively.<br /> </li> <li> <br /> Listen to the spray arms during a wash cycle. If they appear to be moving too slowly, use a wire to clean out the spray holes.<br /> </li> <li> <br /> Make sure the dishes haven't blocked the detergent dispenser or jammed the spray arms.<br /> </li> Dishwasher Leaks <li> <br /> Cut back on the amount of detergent used during the wash cycle. Sometimes this alone will solve your problem.<br /> </li> <li> <br /> Make sure the appliance is level by adjusting the front feet up or down.<br /> </li> <li><br />Take off the lower front panel and check the hoses for leaks.<br /></li></ol><span><br /><br /><a href="http://www.ehow.com/how_2120626_troubleshoot-dishwashers.html#ixzz18lyYrfk2"><br /></a></span>
on Dec 21, 2010 | Dishwashers
Poor rinse on maytag model mdb8600awq
Did you check the screen at the bottom of your dishwasher? It may be clogged with food particles. If these particles aren't small enough to get flushed down they will just recycle through the water.
I always make it a practice to rinse off my dishes before I place them in the DW. Some newer models have better drainage systems, but perhaps yours is an older model.
Dec 22, 2012 | Maytag Dishwashers
My dishwasher is not cleaning dishes well
Hi.
A dishwasher may clean poorly for a number of different reasons. Before replacing parts or looking for a fault I suggest going through the following checklist:
  • Make sure you are not using a rinse only cycle, test using Hi Temp Wash cycle and Hi Scrub.
  • Check that you are using proper detergent, as suggested in the manual.
  • Make sure you are using rinse aid.
  • Make sure that dishes and pans are correctly positioned in the baskets.
  • Check if stains go away when you soak the glasses in vinegar. In that case the problem is hard water. Correct the amount of detergent as from manual.
  • Check that the arms are free to rotate.
  • Check for leaks in the duct to the upper spray arms, make sure that the upper spray arm is well mounted.
  • Make sure that incoming water from the house has pressure and that hot water has temperature specified in manual (e.g 120F-50C).
  • Check for food obstruction in the drain or disposer.
  • Check that the drain hose at the back is not kinked.
  • Check that the machine is completing the cycle.
  • Try running a light cycle with both sides of the detergent cup filled with soda or Jet Cleaner product.
If none of the above is the problem, then improper cleaning may be caused by a faulty part. Parts that may result in poor cleaning if faulty are:
Accumulator Filter connected to pump
  • Drain hose, duct and drain lines
  • Detergent release system.
  • Spray arms.
  • Spray arm ducts and flappers.
  • Seal and Chopper Kit (if installed)
  • Wash Impeller pump.
Regards.
Ginko
Dec 11, 2011 | Dishwashers
Dishwasher will not clean well leaving a lot of particles, etc. on dishes.
Hi Jim.
  1. Make sure you are not using a rinse only cycle, test using Hi Temp Wash cycle and Hi Scrub.
  2. Check that you are using proper detergent, as suggested in the manual.
  3. Make sure you are using rinse aid.
  4. Make sure that dishes and pans are correctly positioned in the baskets.
  5. Check if stains go away when you soak the glasses in vinegar. In that case the problem is hard water. Correct the amount of detergent as from page 7 on manual.
  6. Check that the arms are free to rotate.
  7. Check for leaks in the duct to the upper spray arms, make sure that the upper spray arm is well mounted.
  8. Make sure that incoming water from the house has pressure and that hot water has about 120F(50C).
  9. Check for food obstruction in the drain or disposer.
  10. Check that the drain hose at the back is not kinked.
  11. Check that the machine is completing the cycle.
  12. Try running a light cycle with both sides of the detergent cup filled with soda or Jet Cleaner product.
If none of the above is the problem, then the most common faults with this model that result in incorrect cleaning are caused by the following parts. Please refer to the part manual to find diagrams and part location.
  1. Accumulator Filter (part 7 in Pump and motor diagram)
  2. Docking Station with Flappers(part 3 in Water Distribution Assembly)
  3. Seal and Chopper Kit (part 9 in Pump and motor diagram)
  4. Wash Impeller(part 6 in Water Distribution Assembly)
Locked flappers and clogged filter are the most common causes that may result in improper wash.Please refer to the part manual to find diagrams and part location.
Here parts manual with diagrams and part list.
Here the manual: Owner's Manual - MAYTAG Dishwasher MDB6601AWQ, MDB8751AWB alternatively Click here to download manual.
Here Tech Sheet.
Regards.
Ginko
Dec 04, 2011 | Maytag 24 in. MDB7601AWS Stainless Steel...
What would cause my dishwasher not to drain?
not sure if you have posted the model number of your dishwasher.
There are several reasons for dishwasher not to drain.
1. faulty drain pump
2. clogged kitchen sink drain
3. drain cycle is not reached due to faulty dishwasher controller
4. clogged drain hose
5. the wash cycle is not completed due to heater not heating water - (try rinse cycle to confirm)
Happy to help if you can provide some details on when the drain cycle is not working. do you get any alarms on dishwasher..etc.
Feb 25, 2011 | GE Nautilus 24" Built-in Dishwasher
The dish washing powder does not wash out completely unless the machine is set to heavy duty only. we will often open the machine at the end of a wash cycle and see the soap powder all wet and soft but not...
Seems to be problem with spray arm pressure. Check the spray
arm jet nozzles.
Check the incoming water flow to the machine. clean the strainer fitted at the washing machine end connection.
Being in the extended warranty, take the help from
the service provider.
Aug 31, 2010 | Dishwashers
Cloths stink, towels not soft. Can I increase the amount of water used per cycle? How? thanks, jim maxwell
Make sure there are no leaks from the machine. Look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose and door rubber is completely clear of debris and soap scum build up and check that the filter is clean.
You can initially use a bathroom mould and bacteria cleaner to get rid of the immediate problem or wash using a bleach solution made up from 1 part household bleach to 10 parts water. Place this in an aerosol spray bottle and spray the affected area and leave for 10 mins then wipe away and rinse with clean water.
  1. To keep the machine clean of waste or mould build up and to keep any bad odours away
  2. Remove all items from the washer.
  3. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
  4. Close the washer door and dispenser drawer.
  5. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
  6. Press Start and allow cycle to complete.
  7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
  8. Repeat the cleaning procedure monthly
Also from your description it sounds as though you need to use a water softener (washing soda) or use slightly more deteregent and possibly more fabric conditioner inthe wash. Also washing performance can be increased by using slightly higer temperatures and / or a bilogical detergent.
Nov 09, 2009 | Maytag Neptune Washer
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwashers Logo
184 people viewed this question
Top Dishwashers Experts
