Question about Pentax K100D Digital Camera
Pentax K100D will not power up
When the K100D camera is turned on the battery icon continually flashes and thats it. Nothing works, no LCD screen and can not connect to the PC. Tried fresh batteries with the same issue. Please help
  • rodtaylor101 Jan 22, 2009
    thanks for the advice. I replaced the rechargables with new disposables and the camera worked fine. I have since replaced the rechargables and they work OK too.
    Scholar:
  • 58 Answers
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Posted on Jan 21, 2009
  • Gordon Stalker
    Gordon Stalker Jan 23, 2009
    Also some NiMh batteries have an odd discharge curve. (The way the voltage changes as the battery discharges.) They start quite high and rapidly drop to close to the nominal value, they then dip slightly lower for a while, and bounce back before falling again.
    New technology niMh, with low self discharge rates (Eneloop etc.) can show a marked dip in the discharge curve. So a battery which has only been used a little, can drop below the minimum set point for these cameras, and then after a while recover.
    The voltage is also dependent on temperaure, so if your camera signals low voltage unexpectedly early in cold weather, take them out and put them in a pocket for a minute to warm them a little. This should allow them to get past the dip.
  • zeusserg
    zeusserg Jul 25, 2012
    Hello! How reset the camera?
New Pentax K100D Super, shutter does not work. Av -- flashing 688 under battery sign. Replaced new batteries did not resolve problem
I suspect dirty contacts on either lens or body. Clean contacts. Should alleviate problem. This happened to my K100d.
Dec 11, 2010 | Pentax K100D Super Digital SLR Camera
Won't turn on even with new batteries
Clean the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Dec 17, 2009 | Pentax K100D Digital Camera
New batteries fitted but low battery flashing and wont switch on in K100D
Try cleaning the battery contacts in the camera with a cotton swab lightly moistened with rubbing alcohol.
Nov 17, 2009 | Pentax K100D Digital Camera
Display option
Pentax K100D does not have Live View function. So you can't preview the image before taking the image.
Feb 08, 2009 | Pentax K100D Digital Camera
LCD screen flashing
Hi!
This is a feature and not a defect of the K100D. You can turn this off by going to the menu and going into the second tab (playback menu). Once there, go to preview display, where you will have 3 options - off, histogram and brighten areas. Set this to off (your camera is set to brighten areas, that is why the white parts of your photos appear to be blinking).
Hope this helps!
Oct 27, 2008 | Pentax K100D Digital Camera
Pentax K100 problem
Might be temporary lack of communication between lens and body - try cleaning the contacts on both gently with a lint-free cloth and a very little IPA.
Jul 17, 2017 | Pentax K100D Digital Camera
No pic framing on LCD display - playback is OK
ON digital slr cameras there is no pic framing on the LCD display.
Apr 25, 2008 | Pentax K100D Digital Camera
K100D flash doesn´t work
My camera with the dodgy flash is holidaying in Japan as they sent it to be fixed - not sure how old your camera is but I am trying to see if this is an issue that occurs with the camera model.... given that there are only two of us to date I am thinking that we may have just struck the jackpot :(
Dec 27, 2007 | Pentax K100D Digital Camera
Pentax K100D DSLR
The interface IC ( between the main CPU and the CCD sensor ) seems faulty . Camera should go to the Pentax agents unfortunately.
Sep 02, 2007 | Pentax K100D Digital Camera
Pentax K100D Digital Camera Logo
1,074 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
