Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Wireless router can't find router's administration tool on laptop,to set up wireless router.
  • 50 Answers
Hi
router administration tool can be open through browser (Internet Explorer). you need to make sure that laptop is connected with router by direct cable or through wireless connection
Step 1 Open your web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The default username is admin and the password is blank (nothing). Click OK.
this will open the router administration tool.
Please vote if this solution is helpful.
Posted on Dec 31, 2008
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
Tip
How to set up wireless home network with a DSL subscription.
If you have a DSL, "Digital Suscriber Line", most companies will provide you with a modem. Usually the modem will have only one ethernet connection, meaning you can only connect one computer.
In order to connect multipule computers you will need a wireless router, ethernet HUB, or router.
Connecting with wireless Router
The only thing you really need to change is the following 3 settings on the Wireless Router. The SSID (so you know what wireless network is yours), the WPA/PSK and or WPA2/PSK, encryption method TKIP key or password. Under "administration" change the administrator password for a secure wireless connection. ( WRITE DOWN YOUR PASSWORD)
Connect to your wireless router
1. Plug in either your (1) wireless card, (2) PCMCIA wireless card, or (3) USB wireless stick.
2. Turn on your laptop or desktop computer. Select the wireless router with the strongest signal and with the name of your routers (SSID) and click connect.
3. Open your web browser and type 192.168.1.1
If this dosn't work, check your wireless router instruction manual for the correct IP address for your model.
4. Your router will ask for a password, usually (admin, admin) works or (admin, (ENTER) ) try both. If neither work try resetting the router by holding in the reset button for 3 seconds.
Once you log on to your router you can set parameters to your liking or just set the , {SSID}, {WPA/TKP} key or password, and the router administrator password to keep others from accessing your network and possibly computer.
Ethernet
Start at step 3 above.
More questions?
on Feb 05, 2010 | Computers & Internet
Forgot administrator password for belkin n wireless router model F5D8236-4
To reset the Belkin back to the default settings -
Press and hold the pinhole RESET button at the back of the router and then power for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 24, 2013 | Belkin F5D8236-4 Router
Password protect wireless access
You'll need to access the administrator web page for your router, and then set a security key (password) for wireless users.
For step-by-step instructions for setting up security on the D-Link DI-614 router, see:
http://technicallyeasy.net/2010/10/how-to-secure-d-link-di-614-wireless-router/
Sep 04, 2012 | D-Link 2.4GHz Wireless Router DI-614
My laptop will not conect to wireless unless it is wired to the router? is there a fix for this?
A couple of things to check.
Is the wireless router using WIFI? (Obvious question I know)
- If not, connect to 192.168.1.1
- Login = admin, password
- Activate wifi
If your router has it's wfi turned on, try the following;
- Start, Control Panel, Administrative Tools, Services and make sure WLAN Autoconfig is set to Automatic and started.
- Also make sure the following services are set to Automatic and started:
- Windows Connect Now
- TCP/IP Netbios Helper
- Simple TCP/IP Services
- Network Connections
Good Luck
Mar 09, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Had to reset router to factory settings now want to reset pasword
If you have your router at default settings do the following.
Open a web browser and type 192.168.1.1 into the address bar. This should pull up the settings for the router.
The username is likely "admin" or "administrator" and the password "admin", "administrator" or "password". Once you're into the router you can change the settings as you wish.
Jan 27, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
How do i change the mtu setting on my belkin n wireless router
You can adjust MTU from within the Belkin Router administrative console. You really should not be changing it unless your current ISP gives you a specific MTU setting, otherwise you could disrupt internet connectivity.
Default IP address: http://192.168.2.1
Default admin username: Administrator
Default admin password: <blank>
Be sure to set a password for your router!
This is the address where you change MTU
192.168.2.1/wan_pppoe.html
Belkin Wireless G User Manual:
http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=5999&scid=221
Windows Tools to adjust MTU:
DrTCP tool:
http://www.dslreports.com/drtcp
TCP Optimizer
http://www.speedguide.net/downloads.php
Jun 09, 2009 | Belkin (F5D7633UK4A) Wireless Router
Wireless connection problems
How bout setting ur mom's laptop to remove all wireless connection history and then try to make new connection to the router at her home. It also recommended to see from the router
administrative tool is your mom's laptop detected? no kind of blocklist applied in the router? Hope it helps :)
Dec 18, 2008 | D-Link DI 514 Wireless Router (DI-514)
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Cant connect
Roger Dodger.. Make sure that your security1.gif password is correct.
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless zero client are started and set to startup type automatic.
Oct 11, 2007 | NetGear RangeMax 240 WPNT121 (WPNT121NA)...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
51 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
