Computers & Internet Logo
Posted on Dec 31, 2008
Back light on GoBook III
Tried pressing the num-lock, caps-lock, and scroll-lock it did not work. Any other suggestions?
WHAT IS THE ICON ON TOP TO THE LEFT OF THE CAPS LOCK ICON? HOW DO YOU TURN IT OFF?
This is either the Num Lock or the Scroll Lock. To turn off the Num Lock, look at the top left of your number pad on the right side of the keyboard, and press the Num Lock key. To turn off the Scroll Lock, press that key in the middle of the top row of 3 keys above your arrow keys.
1helpful
Compaq Keyboard -- top right hand corner, the light next to the CAP LOCK is lit. What is this for?
Num Lock ----- Cap Lock ---- Scroll Lock
  • Num Lock --- use numeric keypad
  • Cap Lock --- all capital letters
  • Scroll lock --- stop screen from scrolling ( pause screen )
6helpful
2answers
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
3helpful
2answers
IOGEAR KVM gcs632U. Set up notes that to "toggle" between PCs you press SCROLL LOCK twice. My keyboard has no SCROLL LOCK so to change you are supposed to press NUM LOCK + "-"...release "-" after 1...
OK well usually in the "Setup" you can "Assign" whatever keys you need, so can't you change the keys used to what you have? ALL Keyboards have scroll lock, it is probably just "Hidden" for instance I found one accessed via pressing a Blue Fn Key and then F12. Look carefully for "Other: small writing on keys.
8helpful
2answers
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
3helpful
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
2answers
Keyboard question
using thes keys;
i)Num Lock(on top-right corner)
ii) Caps Lock(on bottom-left corner
iii)Scroll Lock(on top row -right) on your key board
Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
My acer aspire 3690' s key pad locked. please explain how i can unlock it.
try the following:
  • press scroll lock/num lock, if no success then
  • press and hold fn key then press scroll lock/num lock, if even no success then
  • press and hold shift key then press scroll lock/num lock.
and please post your feed-back
Thanks
Iqbal
Top Itronix Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
