Run the lens cleaner through a couple times if that doesnt work then your lazer eye could be bad send out for repair or ebay a new one and sell that one on ebay there are some people who will buy it broken cause they can fix it cheap and sell it good luck...
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say "no disc".
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get
By so doing your player would play all DVD's with no problem at all.
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it skip.
Ok, it sound to me that the laser lens which actually reads the cd's has some dirt particles on it.
There is a very cheap method of solving this problem. Just go to any cd shop and buy yourself a decent laser lens cleaner disc, follow the instructions and you should be set.
Hello my friend,
I suggest to test with many different CDs, if it's still skipping in all CDs. i will say that it's a lens issue, in this case you buy some CD cleaner which has some special lotion which clean the lens. but if this doesn't help also, at this time i will say that the lens needs to be replaced and i hope that you device is still under warranty because the repair will be free for you.
Best Regards,
Your LG dvd player's lens might need cleaning. It is having a hard time reading those cds that is why it sometimes skips or just stops in the middle of playing them. Does this happen also to new cd's? Sometimes cleaning those cds helps the lens reading them.
If you have a disk cleaner, you can run that for 30 seconds on your player. It that does not help, then you might need to open your DVD player's casing and clean the lens manually by opening your player, get a soft cotton earbud and damp in an alcohol and gently wipe your dvd's lens. Then try to return back everything and test playing cd.
Ive replaced sooo many Bose systems for that very same reason. Id replace radio. Problem with Bose radios sometimes have no amp inside radio and if you replace the radio, you have to replace the entire system, very expensive, depends on year of vehicle too.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully. If that seems intact, (and you feel comfortable doing it) check the traverse assembly (the metal rod that the laser travels along
and the gear that drives it) if CDs aren't recognized or won't play,
frequent skipping occurs at random, CDs randomly get stuck in one spot,
the player can't find tracks correctly, or cleaning the lens doesn't
work. Dust and lint may be interrupting its function.
If that doesn't work then have the laser-head assembly checked by a repair person if the traverse
assembly seems intact and free of debris.
