Question about Frigidaire FRS26R4A Side by Side Refrigerator
Freezer defrosted but refrigerator still works
Freezer compertment is hot and defrosrted but the refrigerator side still works. it makes a humming noise for about 30 seconds about every 3 to 5 minutes. this is a frigedare about 3 years old.
    Problem Solver:
  • 16 Answers
Sounds like the compressor is not running properly. It will overheat and shut off, then restart after a few minutes when it cools off. Check the coils (on back or under) to make sure they are clean. You can do this with a vacuum, or a can of compressed air from the store.
Posted on Dec 31, 2008
Ice maker make noise and back of freezer is frozen
THE DEFROST CONTROL IS OUT MAY BE THE DEFROST BYMETAL OR A TIMER OD DEFROST HEATER WHAT BRAND AND SIDE BY SIDE OR TOP AND BUTTEM REF. AND AGE. WILL HELP
Feb 21, 2012 | LG LSC27910 (265 cu ft) Side by Side...
Side by side refrigerator is making a sizzling noise at the back bottom of the freezer
The sizzling in your case means that it is working....it is just water dripping from the cooling coil onto the hot element that defrosts it...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 18, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
Jun 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer is iced over and making a humming noise bottom of refrigerator not working
sounds like a defrost problem. your coils are froze over and not letting any cold air to the bottom. either the defrost timer or defrost heater.
Oct 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Humming and frosting in freezer
Your defrost has stopped. Either the defrost heater, bi-metal or the control board has failed.
Sep 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
MSD2656GEQ The coils on the freezer side ices up, then does not cool the refridgerator side
Hi, It's a common problem with no-frost refrigerators, you have a defrost problems, two scenarios. (1) hot air entering freezer/refrigerator, examples. hot summer days, regular openings, high room temperatures, hot foods and broken door gasket, leaving freezer/refrigerator doors slightly open overnight, could cause your evaporator (coils) to freeze/ice up. cases like this, unplug/disconnect your refrigerator, remove produce, clean and let it defrost, for an hour, make sure all ice melted. plug or reconnect your refrigerator let it work/ run empty for another hour, then put back your produce. sure it will work perfect for the next 3-4 days. (2) next type of defrost problem could be faulty defrost heater, defrost thermostat, you will have to open back panel on freezer side to check. check your defrost heaters, defrost thermostat and defrost timer, it's better to change defrost timer and defrost thermostat together, or change faulty ones independently. but before you change any parts, clean and defrost refrigerator first, could just be regular openings, hot days, etc. if after 3-4 days it started to ice up, then check following parts. defrost heater. defrost thermostat and defrost timer, let me know if icing occurs after 3-4 days then we can check those parts i suggested. remember to always disconnect/unplug your refrigerator, before attempting any repairs. good luck
Aug 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
Frig side not working on Maytag MZD2766GEW
freezer not defrosting. probably adaptive defrost board in fridge.
take panel off freezer (inside, back panel). if all frozen, can defrost with blow dryer. best to remove fridge control panel (inside, top of fidge). access adaptive defrost board, jump test to f1 (i think) next to test. this should initialize defrost mode. buy new board.
May 23, 2009 | Maytag MZD2766GES Side by Side...
Oil leaking out from under freezer side.
That oil is probably compressor oil. If the compressor leaks, you need a new fridge. Sometimes they only leak when they're charged up. That would explain the other symptoms.
Oct 16, 2017 | Frigidaire FRS26H5AS Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
73 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
