Question about Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver
Blackberry 8130 disconnects from Network after 10-20 seconds
In spite of going through a software update, soft reset, hard reset and restore of the phones memory, the phone will still not stay connected to the Verizon Network for much more than 20 seconds.
I have run a Services Status diagnostic and the original message i got back before the report was delivered read "APN List is empty!" Do not know if this is signififcant.
Does this really mean my phone is "broken" and I need a new one?
  • 1 more comment
  • Anonymous Jan 19, 2009
    I AGREE. I HAVE THE SAME DAMN PROBLEM. I have been reading that alot of people have this same problem. WHy the hell did I pay over 200 bucks for a phone that will break within a year
  • Anonymous Feb 24, 2009
    I have the same problem, but I just received this new phone in the mail today.  It was a replacement phone under warranty because my last one stopped charging.
  • Anonymous Mar 13, 2009
    i have the same phone and same problem and im not happy and its not fixed i dont know what i can do to fix it
    Sniper:
  • 92 Answers
You can always try and reprovision your phone and resend the Host Routing Table (HRT) but if it is constantly dropping service it is probably a hardware issue and not something that can be permanently fixed. It could also be a radio issue but I would take it back and request a new one.
Posted on Jan 24, 2009
I am trying to manually program my Blackberry 8130. When I go to options it does not have a network setting in it. So how would I do it. Thank you Pattie
You can reset your blackberry phones then try to access that option again, if still have same result, Unlock your blackberry network using blackberry pearl 8130 unlock code. It should be unlock your network and you can try to access that option again. If your unlocked blacberry network still have same problem, go to final option to reflash your phone.
Jul 14, 2011 | RIM BlackBerry Pearl 8130 Cellular Phone
Blackberry Cure 8310 app error 205 rest
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Jun 16, 2011 | RIM Blackberry 8310 8320 8330 Curve 8100...
9700 is frozen on the "loading" screen. Tried hard and soft reset...won't work!
I would suggest then that you try a software update:
http://us.blackberry.com/support/downloads/download_sites.jsp and select your network to download
This hopefully should resolve, although freezing can sometimes be due to a lack of memory, try software update but use it for a day or two without restoring your data to make sure that it isn't one of your files corrupting the handset.
Feb 03, 2011 | RIM BlackBerry Bold 9700 Smartphone
Blackberry 9000 smartphone - says bluetooth disabled - and when go into options to enable bluetooth - the screens says enabling bluetooth but nothing further happens
Hi, reset phone after resetting phone if nothing happens,Go to blackberry sites for update.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Thanks.
Aug 25, 2010 | RIM BlackBerry Bold 9000 Smartphone
Jum Error 517??
Hi,your phone is corrupted,need to reset or update with firmware.
Use this instruction to reset
Thanks.
and after resetting if no response,then you will need to update with firmware.GO to blackberry web site for update .
Aug 12, 2010 | RIM BlackBerry Bold 9700 Smartphone
My blackberry pearl keeps freezing up and its only 3months old
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 12, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
Unable to receive emails on verizon blackberry
Jan 09, 2010 | Verizon Communications BlackBerry Pearl...
Need to get back a default software/application but how?
Resetting the BlackBerry device is a useful way to resolve issues and is usually the first step in troubleshooting the BlackBerry device. Knowing the differences between a hard, soft, double-soft, and master reset ensures that the correct troubleshooting method has been chosen. Note: Backup all applications before resetting the BlackBerry device using the Backup and Restore tool on the BlackBerry Desktop Manager.
Please follow the below steps or resetting
Performing a SOFT reset on the BlackBerry device Performing a soft reset stops all applications on the BlackBerry device by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. A soft reset re-establishes communication between the BlackBerry device and the computer.
Note: This does not apply to the BlackBerry® Pearl™ smartphone.
Performing a DOUBLE-SOFT reset on the BlackBerry device Performing a double-soft reset stops all applications on the BlackBerry device and is nearly the equivalent of a hard reset. Timing however is critical. Perform a soft reset by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen is no longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You should then see another blank screen followed by an hour glass.
If you liked my response Please do Rate this solution.
May 04, 2009 | RIM BlackBerry Bold 9000 Smartphone
App error 523
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:1) Remove the battery cover from the back of the BlackBerry smartphone.2) Remove the battery, and then reinsert it after a few seconds.3) Replace the battery cover.
A soft reset is a three key combination that resets the BlackBerry smartphone without removing the battery. It is only available on BlackBerry smartphone models with a QWERTY keyboard. SureType technology and touch screen BlackBerry smartphones, such as the BlackBerry Pearl smartphone, BlackBerry Pearl Flip smartphone, and BlackBerry Storm smartphone cannot be reset in this manner.
To perform a soft reset, complete the following steps:1) Press and hold down the ALT key on the smartphone.2) While holding down the ALT key, press and hold down the right-hand CAP key.3) With both of those buttons still pressed, press the DELETE key. The display on the BlackBerry smartphone will turn off to indicate that the reset has started, and the keys can now be released.
Mar 13, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver Logo
1,842 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
