Question about Hitachi CP-X327 Multimedia Projector
No picture from projector after changing lamp
Change lamp & clean filter instruction came up Changed lamp &cleaned filter but did not reset-no manual Pressed reset could not get rid of screen. Power & lamp light flashing Now switch power on , power & lamp lights on ,no screen, Fans appear to work normally
How to change the lamp
Posted on Oct 11, 2008
I have a problem with my Canon LV-7265 Projector. When I turn it on, a message appear "please clean the filter" with a blue windows! Please help me how to fix this problem. I try to clean 2...
You need to go into the settings menu and find the lamp reset and filter reset area, sometimes when you get to the reset part you hold down enter then an additional box may show reset/OK, select OK which should reset the filter hours. Most projectors have the filter reset but sometimes resetting can be difficult to work out. I had an old NEC where you had to hold down the on button of the remote for ten seconds to reset.
Hopefully this helps. There may be support from the manufacturers website plus downloadable user instructions.
Good luck
Aug 04, 2011 | Canon LV-7265 Projector
Failure to change Filter Time
unplug projector for about an hour, and then remove bulb, and filter, inspect areas for damage, also inspect it to make sure your inserting it correctly. put filter and bulb back in, put covers back on, then plug it back in. reset the timer. if you still have problems let me know.
May 06, 2008 | Hitachi Performa CP-RS55 Multimedia...
After 2 mins on the bulb goes out
Need to change bulb and reset the lamp timer. When was the last time you clean the air vent filter. Clean it and reset the air vent filter cleaning timer
Aug 10, 2010 | 3M EP7630LK Projector Lamp for MP7630,...
What does the red light mean?
The red indicator light usually comes on when something needs attention. Most often it has to do with the lamp timer or the filter timer. The projector keeps track of how long it's been since you've changed the bulb or cleaned the filter(s). You can reset these timers in the menu. Be sure to clean the filter before you reset the timer. :)
Jan 17, 2010 | Optoma HD65 DLP Projector
Projector keeps turning off every 5 mins
if just the lamp turns off and the rest of the projector is running, it's time to change the lamp. if the whole projector turns off (not goes through shut down), it may be a power supply problem.
Aug 19, 2009 | Panasonic PT-AX100U-EC DLP Projector
The clean your filter warning sign comes up and then shuts the projector down in 1 min. I have changed the lamp and filter. How do i reset the timer for the Lamp Hours and get rid of the warning?
Once the filter is replaced, plug the projector back in and make sure the projector is in standby mode.  Point the remote control at the projector and press the following buttons in order in less than 3 seconds: reset, ←, →, enter.  This worked for me.  Good luck.
Feb 21, 2009 | Sony VPL-VW100 (Ruby) Multimedia Projector
I have 2 SVGA60 Projectors that are saying Temperature!!! One does it then the other about 10 minutes later
several reasons, it could be you havent had its 1000Hrs service and is overheating or filter needs cleaning or lamp is past its change time and is generating too much heat or sensor can sometimes come away and drop into light path causing false sensing of temp.
Marc Engineer
Dec 17, 2008 | Mitsubishi HC100U Multimedia Projector
My projector keep shutting down
After replace the lamp. Please reset the lamp hours and clean the filter. It should work.
Apr 07, 2008 | Office Equipment & Supplies
Hitachi CP-X327 Multimedia Projector Logo
956 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
