Question about SPV Wayne Pumps Spv500 1/3hp Cast Iron Pedestal Sump Pump
1/3 hp wayne pedistal sump stoped working
Checked the pump, pump has power to the switch and has power after the switch , impeller and shaft are clean and clear. pump will not run.. is ther brushes in the motor/can they be changed?
  • 332 Answers
Yes there are brushes,, but there is also a shaft that goes thru the tube make sure it is not broke or bent,, it happens,, suggest to get a zoeller submersable pump its the best cast iron, float is attached to the unit, will fit in small pits, only 1 plug needed,, cost for pump 100
Posted on Jun 23, 2009
  • 2 more comments
  • gary miller
    gary miller Jun 27, 2009
    yes there are but by the time you took to take the brushes out, you could replace the pump,, any electric motor has brushes, thats what makes it work with the magnets to make it spin,
  • gary miller
    yes all electric motors have brushes but inmost cases it is cheaper and eaiser to replace it when it comes to a sump pump
  • gary miller
    gary miller Jun 29, 2009
    you can change the brushes but by the time you took to do this you could install a new pump
  • gary miller
    gary miller Aug 01, 2009
    yes there are brushes on al electric motors, but if you turn the shaft or propeller does it turn the motor,, alot of times the shaft breaks inside the casing and this is the only way to check out side of flipping it over and trigering the switch and see when the motor comes on does the propeller try to spin or not
Impeller runs, no water comes out. Removed output hose, air is blowing out when removed from sump.
Remove bottom cover, check for clogged intake holes, and make sure the impeller is solidly attached to the shaft. Can you see the water in the sump? Is the sump full of sand at the bottom?
Jun 28, 2015 | Utilitech 1/2-HP Cast-Iron 83 GPM...
Parts manual for ESP15 12 v backup sump pump-impeller bad
you must contact to the supplier manufacture in your owner manual, call them or go via ONLINE chat for to get support or download your manual from www. fitness.manualsonline.com or www.retrevo.com
God bless you
Nov 04, 2013 | Wayne 12V Battery-Powered Backup Sump Pump...
I Noticed that there was dirt in the sub pump system, I took it apart got it working, bit for some reason it wont **** up the water? I was wondering if you could tell me why? thanks
Maybe you installed the check valve upside down and the water will not pass through a check valve that is facing down instead of up. If you took the bottom strainer plate off the pump and cleaned it out in there, the pump impeller may have stipped its splines and consequently only the shaft turns. Usually I find small stones, string wood chips etc. that stop the pump. The breaker should pop if it is the proper amperage, when stopprd up with debris. Good luck. Hope this helps you solve your problem. Please post to fixya.com if it does, so I get the credit for the solve. Let me know if you do need more advice. I will be happy to give you the whole lowdow on sumps if you wish.
Jan 02, 2011 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
How to troubleshoot toilet sump pump?
Unplug the sump pump. Bail out the sump pump to expose the pump's machinery.
Inspect the rod attached to the motor on the top of the sump pump. Move it up and down manually to see if it moves smoothly. Corrosion will keep the rod from moving smoothly. Clean the float road with steel wool.
Inspect the float ball. If it contains water, you need to replace it. Unscrew the float ball from the end of the float rod and screw on a replacement float ball.
Inspect your sump pump's check valve. It has an arrow on it. The arrow should be pointing away from the pump. If it's pointing towards the pump, remove and reinstall the check valve.
Locate the small weep hole between the check valve and the pump. Clean it out with a pipe cleaner.
Inspect the impeller, which is the fan-like piece that sits near the bottom of the pump's tank. If it is clogged by debris, then it will not turn properly. Unbolt the impeller and clean away any debris you find. Reinstall the impeller with new gaskets and sealant. Locate and replace the mesh filter in the sump pump, since only a damaged or missing filter would allow debris to get near the impeller.
Below is troubleshooting work, web link, through to assist you in that.
http://www.plumber-washingtondc.com/articles/sump-pump-troubleshooting
Jun 25, 2010 | Plumbing
Same issue, one of two pumps
I'm assuming the switch in Question is a Float-switch that is positioned in-line of the Power-supply to the Pump. The hinge that activates the switch inside the Float could be faulty. You can check it by connecting a dif-
ferent device to the plug, activate the switch
(Float upright) and deactivate (Float horizontal)
Mounting the switch with zip ties is a good
idea.The Float should be dangeling about 3"
above the Pumphead, thus keeping it submersed. Hope it helps.
Jul 14, 2009 | Genius Wayne Submersible Sump Pump With ...
No information on Wayne 55701-RP1
This isn't a valid Wayne pump model number according to Wayne's website. Please double check your pump and visit:
http://www.waynepumps.com/producttype.aspx?pt_producttypeid=8
May 23, 2009 | Wayne Water Systems Wayne RECONDITIONED...
Sump pump does not pumped water every time when motor is on
the drive shaft is broke that why it is easy to turn, the pump needs to be replaced
Mar 12, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
SPV Wayne Pumps Spv500 1/3hp Cast Iron Pedestal Sump Pump Logo
196 people viewed this question
Top SPV Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a SPV Garden Expert? Answer questions, earn points and help others
