Question about Apple iPod nano
Screen lock not getting off
By my mistake i turned the screen lock on. before turning on the screen lock ipod used to get opened with itunes after turning on the screen lock it does not get open with itunes i cannot insert new songs.
  • Anonymous Mar 22, 2014
    my child put a lock sreen by mistake
  • 3 Answers
If you do not know the code then you will have to restore the iPod. http://docs.info.apple.com/article.html?artnum=60983 The link is how to do it ;-) - Vince
Posted on May 30, 2007
    Problem Solver:
  • 14 Answers
This is a note to every one as far as i know u do not need to restore your ipod! dont go through the hassle........ try this first
For those forgetful people
all right guys i have a solution for this but it will require some work first:
  • Mount the nano (plug it in)
  • Navigate to X:\iPod_Control\Device\ (where X is the drive letter of the iPod)
  • Find the file called "_locked" and open it with Notepad or TextEdit
now u should get some thing like : Vôáijåö\féúPbíþT~ñâHzõæLvùê@rýîD as the text but its not that con fusing to show here are two different codes
the same endings
]óãhjåö\féúPbíþT~ñâHzõæLvùê@rýîD
so in fact the part that matters is the first 4.... and its a 4 digit code!!
soooo i have made a guide line.. for u to match up your code with
0000
^ðàk
1111
_ñáj
2222
\òâi
3333
]óãh
4444
Zôäo
5555
[õån
6666
Xöæm
7777
Y×çl
8888
Vøèc
9999
Wùéb
now how does this help ?? well i set my code as 1234 and this is what the first 4 digits were: _òão
if u look at the first one and compare to the guide it shows that the first digit is 1 the second 2 the third 3 and the last is 4! taaa daaaa!!!!
Rock on people hope this helps!!!!
~Thimolas the awesome :P
oppps!! forgot to mention that eagle btc helped me find the folder...... the little bit at the begining was from
http://forums.ilounge.com/showthread.php?s=&threadid=118446&highlight=combination+lock
Posted on Mar 12, 2009
I pod touch enable
You can reset it using iTunes. Open iTunes, plug the iPod in using USB, then turn of the iPod, once it's off hold down the home and lock buttons for 10 seconds, then release the lock button while continuing to hold the home button. After a few seconds iTunes should detect the iPod and you can reset it to factory defaults.
Nov 27, 2011 | Apple iPod touch
Tip
How to unlock the iPod Touch, if you forget the password
<p>The screen lock is available on the iPod Touch, as well as recent models of the iPod and iPod Nano, giving you a 4-digit password to set the screen. This is to prevent others from using your iPod, but it is not a safety device impregnable. If you forget the password, you can quickly and easily unlock the iPod by connecting it to the computer you normally use to sync your iPod with iTunes. You can then open the iPod and reset the lock to a more memorable password. <br /> <p><br /> <p>1. Connect the iPod Touch to your computer via the USB cable. <br /> <p><br /> <p>2. Wait for iTunes to access and synchronize with your computer. <br /> <p><br /> <p>3. Take your iPod Touch from your computer, clicking on the "Eject" to the input side of the iPod under "Devices" in iTunes. <br /> <p><br /> <p>4. Disconnect the iPod Touch from the USB cable. IPod touch will turn on and will be available. <br /> <p><br /> <p>5. Tap the menu "General" on the iPod Touch. Tap "Passcode Lock and tap either" Turn off access "or" Change. "When you click" Change Password ", you can create a new password. <br />
on Jul 21, 2011 | Computers & Internet
Tip
Resetting an iPod if you forget your password
<p>The iPod is a security measure to prevent unauthorized access to your personal media player. Apple included an option to set a password to be used to unlock the device at startup. If you draw a blank password, you can still have the ability to unlock the device, but the process depends on the model of the iPod. IPod Touch owners to restore the device to a password reset code. Other iPod owners need only plug it into iTunes to lock the screen around. <br /> <p><br /> <p>Lock the iPod <br /> <p>1. Connect your iPod to your computer you normally sync your device. <br /> <p>2. ITunes load. <br /> <p><br /> <p>3. Click the "Eject" on the right to offer your iPod under "Devices" in the left column of iTunes. The iPod will be unlocked. <br /> <p><br /> <p>4. Select the "Extras" on the iPod. <br /> <p><br /> <p>5. Select "Lock screen". <br /> <p><br /> <p>6. Select 'Turn Off Screen Lock. " <br /> <p><br /> <p>Unlock iPod Touch <br /> <p>1. Connect your iPod Touch to your computer. <br /> <p><br /> <p>2. Open iTunes. <br /> <p><br /> <p>3. Click on the iPod Touch icon on the left "Devices" section column. <br /> <p><br /> <p>4. Select the "Summary" tab. <br /> <p><br /> <p>5. Click "Restore" and confirm the prompt action in the resulting pop-up. Follow the wizard prompts for the restore process to complete. <br />
My ipod touch is locked and i forgot the passcode
You can reset it using iTunes. Open iTunes, plug the iPod in using USB, then turn of the iPod, once it's off hold down the home and lock buttons for 10 seconds, then release the lock button while continuing to hold the home button. After a few seconds iTunes should detect the iPod and let you restore it without the code.
Nov 26, 2011 | Apple iPod touch
Cant unlock my ipod
What generation? What do you mean, the slide to unlock, or the screen lock? If you mean the screen lock, you should connect to iTunes, because some iPods unlock after connecting to iTunes. Otherwise you should reset it with iTunes. But then all your data will be lost. Otherwise you should try try try. You've got 10000 chances ;-) If you have an iPod Touch, you might mean the slide to unlock screen is frozen. I had that one time, after trying out spoken feedback. After that it locked the screen and the touch screen wouldn't work anymore. I couldn't do anything anymore, not unlocking, not turning off spoken feedback, not even turn off the iPod. I was lucky to find there was an update for the iPod so iTunes turned it off. Then it responded also again.
More details next time please!
Jun 22, 2010 | Apple iPod nano
Tip
How to reset the password on your iPod when you forgot it
<p>Apple included an option to restrict access to your iPod through the creation of a PIN code to lock the screen and to keep unwanted users. Unfortunately forgot your password, not being able to access your music when you're on. If you draw a blank password, you can reset it, but not before you get home to your computer. Use your iPod to your iTunes software to reset the security code. <br /> <p><br /> <p>1. Connect your iPod. Enter the password appears. <br /> <p><br /> <p>2. Connect the iPod to the computer you normally sync. <br /> <p><br /> <p>3. Run iTunes and wait for the iPod name appears in the left pane of the iTunes window. <br /> <p><br /> <p>4. Click the "Eject" icon next to the iPod name in the left pane. The device is unlocked. <br /> <p><br /> <p>5. Select "Extras" iPod. <br /> <p><br /> <p>6. Open the "Lock Screen" option. <br /> <p><br /> <p>7. Select "Turn off Screen Lock" Lock Screen menu. <br />
Code for ipod touch
If it was locked and you donot know the password then the only thing you can do is restore it using dfu mode hold both power and home button until it turns off and restart and show you to connect to iTunes2_bing.gif. Then restore it. Let me know what happened.
Jan 08, 2010 | Apple iPod touch
Locked i pod
Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod.
For example, if you use Screen Lock and then connect your iPod to a computer, you'll still be able
to manage music on your iPod with iTunes and access all data on it in disk mode (contacts,
notes, and any other files you have stored on the iPod).
To unlock it, connect iPod to the primary computer you use it with (the first one iPod synced with),
and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using this method, you can restore your iPod to factory settings. Please
note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
To restore your I-pod, do this:
1) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software
may need to be downloaded to your computer.
2) Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that
came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes.
3) Select your iPod in the Source panel and you will see information about your iPod appear in the
Summary tab of the main iTunes windows.
4) Click the Restore button. You will be prompted with one or more restore options that may prompt
iTunes to automatically download the latest iPod Software. Use restore option 4.
Sep 17, 2009 | Apple iPod nano
Locked forever
In the Apple Support Site, Apple notes that the "Screen Lock" function:
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This supportdocument aso provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize.
May 26, 2009 | Apple iPod touch
Ipod is open but i cant play any song..its lock .What will I do?
"Screen Lock" is provided by the iPod nano, iPod (5G), and subsequently released iPod models. Earlier iPods do not offer this feature.
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally--not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Jan 03, 2008 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
