Question about HP OfficeJet J4580 All-In-One Laser Printer
Scanner will not scan
I have the incon for hp solution center but am unable to pull it up so that I can use my scanner. The message says that I need a CD-Rom in order to pull it up. There was no CD-ROM sent when I purchased the system. My system is new. I need to know how to reslove this problem or you all need to send me the CD-ROM for the Solution Center. I am unble to use the the scanner but I can print.
    Scholar:
  • 82 Answers
Hi
Please download this driver from the HP official website
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3645100&lc=en&cc=in&dlc=en&lang=en&cc=in
and then try to install the driver, It gives u option while installation
Choose Appropriate option
May be "Repai" can solve the problem
all the best
Posted on Dec 31, 2008
    President:
  • 2,692 Answers
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
How do i scan documents onto my comp
It depends a bit on the software you have installed (OS, etc). If you installed the full-featured software before connecting the all-in-one to your computer, you can scan immediately from the computer. For Windows, open the HP Solution Center (by double-clicking on the icon or Start > All Programs > HP folder > HP Solution Center). Put your document to be scanned face down on the scanner glass and close the lid (ADF pages go face up, top edge first). Click the tab in the Solution Center for your HP product (if you have more than one) and click Scan Picture or Scan Document as appropriate. Set the scanner settings in the pop-up window if needed. Click Scan to start the scan. To use the buttons on the scanner, you need to set the destinations for the buttons in the HP Solution Center (Scan to destination for example) and have the HP monitor running on your computer (this listens to the buttons).
Scanners work with bi-directional communication so USB hubs, print servers or bad cables can result in the printer functions working but not the scanner.
If you install the generic OS driver (by connecting the all in one to the computer before installing the software), the printer will work but the scanner will functions will be limited (the scanner buttons will not work but other functions will depend on the OS). Windows XP can acquire scans in Paint (File > From Camera or Scanner). Windows Vista and Win7 add Windows Fax and Scan which will also acquire scans (not in all versions of Vista). Vista also can acquire scans with Windows Photo Gallery.
The printer works similarly with the Mac OS but hte names may be different.
I hope this helps.
Jun 14, 2010 | HP DeskJet F4280 All In One Printer InkJet
Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
Sep 17, 2009 | HP Photosmart C5280 InkJet Printer
Can not scan
the scanner driver is not installed on your computer you have to install the driver for your scanner with the cd that was given to you while purchasing the scanner
May 28, 2009 | Computers & Internet
Hp psc 1402 all in one scanner not scanning
just chek in my computer is that show any scanner last on screen if it is then scan thru that tool if there is no scanner icon avalable then i need to set drvier thru device manager... it's help u
Jan 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
Unable to scan using HP Scanjet 3200C in Win XP Pro
Hi Shantala,
HP advises that, on some systems, the scanner hardware may get into an error state that will keep the scanning software from finding the 3200c ScanJet. If your scanner still isn't found after installing this driver and software update, please follow the directions below:
  1. Unplug the power cable from the 3200c ScanJet.
  2. Unplug the parallel cable(s) from the 3200c ScanJet.
  3. Shut down the PC and wait for ten seconds.
  4. Plug in the power cable to the 3200c ScanJet.
  5. Plug in the parallel cable(s) to the 3200c ScanJet.
  6. Power your PC on.
If you still have the problem, uninstall the driver from device manager, and download and run this .exe file version of the driver instead.. and if necessary, repeat the above steps..
ftp://ftp.hp.com/pub/softlib/software4/sj648/sj-1436-3/sj648en.exe
Hope this helps
Chris (ziraffa)
Dec 22, 2008 | HP ScanJet 3200C Flatbed Scanner
HP Solutions Center can not communicate with HP 3500c Scanner
Had exact same problem. Went to HP site and they said to check "add or remove programs" functions (in control panel) and if there are multiple copies of HP software to download their fix. I checked, had multiple copies, downloaded patch and all worked well again.
Sep 21, 2008 | HP ScanJet 3500C Flatbed Scanner
Scanner
Reinstall you software for the scanner .
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1849438&taskId=135&prodTypeId=15179&pro
Jul 23, 2008 | HP Scanjet G3010 Flatbed Scanner
How do I get my scanner to put my pics on computer?
get driver for scanner device from hp website.download it from support.hp.com
Jun 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
HP OfficeJet J4580 All-In-One Laser Printer Logo
82 people viewed this question
Ben Johnson
