Question about Electronics - Others
Formating 64gb pen drive
I have a 64gb pendrive after formating with fat32 and copy data on to it, it copies perfectly but when i remove the pendrive and insert it back again the data is not visible but the space is already allocated.
  • 514 Answers
Some memory cards / items do not work with FAT32, you should try to re-format using your PC to FAT16 format.
Posted on Dec 31, 2008
I cannot format my 64 gb TRANSCEND pendrive
use the mfomat utility software and fornat the pen drive it wil shorly solve u r problem 100%.............
Sep 20, 2009 | Electronics - Others
32Gb kingston pendrive not working. Any data copied get corrupted
When i copy any data to my 32 Gb Kingston pen drive whether any audio or video file or any software, the data get corrupted or may be deleted. some trimes it happen that some of the AV files are working. Why this happened that the data are deleted. I have lost many of my files due to this.It cannot be fomatted also. Please sort my this problem. Thanx
Jun 27, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Problem with 32 GB kingston pendrive
i hv a 32 GB kingston pendrive, it can copy any type of data but whenever i copy from pen drive into my pc or copy from my pc to pen drive, it shows multiple empty folders in the same folder n audio-video files got currupted, softwares too. and also unable to delet
May 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Problems with pendrive data gets corrupted
Why not backup your remaining data from the pendrive. Then reformat your pendrive using full format. If it still behave like that , your pendrive is already giving up.
Apr 09, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Pen drive is not working properly
try to replace the unit.
it is possibly faulty.
also you should note that pen disks are not as reliable as hard drives.
Jan 23, 2009 | Electronics - Others
Not able to format my pendrive
Make sure you are attaching your pen drive into an USB 2.0 port (also called "high speed USB port"). It must be formatted to FAT32, if it still fails you might try the HP USB Disk Storage Format Tool. If you are using Windows 98 then you need special driver for your pen drive.
Dec 22, 2008 | Kingston Technologies 512MB DataTraveler I...
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
Cannot copy 4.53 GB mpeg file to 8GB pendrive
http://www.kingston.com/support/USBFlashDrives/faq/pcdt_30.asp
Jul 09, 2008 | Electronics - Others
Problem in pendrive
hey try formating it with fat32
or else you ll have to replace it !!
Mar 09, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Electronics - Others Logo
245 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
