Question about Jenn-Air JED8430 Electric Cooktop
Dual cooktop element stays on constantly at most control settings
We have a JED8430 cooktop and have lost control of the heating at most control settings. For any setting above about 3 on the inner coil, the inner coil comes on continuously and ditto for the dual-coil settings when they are above about 4. In the latter case, the inner and outer coils are always synchronous...even in malfunction. Which part has gone bad? and which part is responsible for generating the on/off cycles that control the heat applied. Are the cycle generating signals and the corresponding closing and opening contacts on the same part or different parts?
  • 1 more comment
  • vdhart Jan 06, 2009
    The only "answer so far was not definitive. Is this what you pay for to get an "expert" opinion? C'mon! I want to hear from someone with hands-on experience!
    Thanks, Vanni. But I need a bit of clarification. According to my schematics, the dual burner has no infinite switch; rather, the analogous part seems to be called a 'dual control'. Is this the part to be replaced? Also, on my schematic, there is no explicit connection between the dual control (or infinite switch) and the solenoid (or whatever) that controls the "hi limit" switch that is responsible for the burner cycling. Does this control line originate from the dual control (or infinite switch)?
    Mohammed387 is way off base. I asked a reasonable question and got a crazy answer. Again, the problem is with the dual element's function and I am trying to decide which part needs replacing. I do not want guessers to answer!
    Sergeant:
  • 221 Answers
Bridge Element
Combines two or three elements into one large cooking area which is ideal for oversized cooking.
Coil Heating Elements
Provide consistent and even heat on cooktop with a plug-in element that is removable for easy cleaning.
Control Placement
Cooktops have burner controls either in the center or on the sides of the surface of the cooktop.
Control Type
Controls can be electronic (digital touch pads) or manual (push-button or rotary knobs).
Cooktop
Cooking surface installed in a countertop or island. The cooktop can have coil or smooth top burner configurations.
Downdraft Exhaust
Available on some cooktops, they are similar in function to a range hood. A fan draws smoke and odors down into the cooking unit and disperses them outdoors through a venting system.
Dual Size Ribbon Element
Offers a convenient choice of using two different sized elements, depending on the size of the pan.
Electronic Touch Controls
An electronic touch-control cooktop has no knobs and is available on electric cooktops. This type of cooktop offers other features as well:
  • If an unoccupied element is left on, sensors in the cooktop will turn off the element.
  • Sensors adjust the size of the element to the size of the pan being used.
  • The control-lock feature for the elements is a safety feature to prevent accidental activation.
  • A digital reminder timer alerts you when the cooking time is complete.Ribbon Heating Elements
    Provides consistent heat from elements beneath the smooth surface, which is directed straight up to the pan for high-speed warm-up and even heating.
    Sizes
    Standard sizes for U.S. cooktops are 24", 30", 36", and 45". Professional series cooktops are available in these sizes: 30", 36", 42", 48", and 60".
    Surfaces
    The outside material of the cooktop or the appliance itself. Glass, porcelain, brushed chrome, and stainless steel are the most common.
    Tri-Ring Element
    Accommodates various-sized pots or pans for the ultimate in cooking versatility.
Posted on Jan 27, 2009
  • 318 Answers
Need to know more about your problems. are you just having problems with the large or small burners? is it happening on all your burners or just one size or just one burner?
it is possible that you may have a switch problem but i would guess that you are just having problems when you use a certain pan.
meaning that you may have a pan that is not flat on the bottom. check the pan by putting a ruler on the bottom of the pan and see if it is flat. of not it wont heat properly and the burners wont work right.
when the burners are set to "high" where the switch, "clicks" on, then the burner should stay on al the time, glowing, any other position it will cycle on and off.
if the burner cycles on and off when set to high then your pan is not drawing the heat from the burner and the "sensor" will shut off the burner until it cools off.
try that ruler test and also try a different pan and different burner to see if they all work the same.
then send me a msg back and i will go further from that.
Posted on Jan 06, 2009
  • Tom Zwiebel
    Tom Zwiebel Jan 06, 2009
    sorry but i didnt see you respond to my questions about which burner and what types of failure you are having.
    with any of the burners, and the dual burner, the infinite heat switch
    is the control. if your wiring diagram shows it being a cycle switch or
    whatever, it is an infinite switch, the dual burners have a special
    switch to control either the small or both small and large sections of
    the burner. either way that is what controls the heat cycles. if you
    are only having problems with one burner then the switch is the only
    answer.
    some times the switch can cause the burner to either heat too much or not at all.
    the limit switch is just a safety of the burner and will only cycle the burner off if it is getting too hot and thats why i was asking if your pans were flat, but you didnt answer that one.
    from what you said to the other posters here i would guess you do have a problem with the dual switch for the large burner.
    next time you want a fast response then send an email response as i am not just reading your question.
    the others that answered your question were not top techs and just people that give responses to anything and not real people who have experience to your repair needs.
    sorry but we do our best to get back as our time allows.
  • Tom Zwiebel
    Tom Zwiebel Jan 28, 2009
    i tried to send you a response to the email i just got, but i dont see that answer showing up, so i will sum it up again here.
    you do have a problem with the infinite heat switch for your right front burner. it is the dual control as listed on your wiring diagram.
    when these type of switches fail they will not be able to control the amount of on and off time to regulate the heat from the burner. they also do make a clicking sound when they cycle and that is normal, but what you are having for a problem is the percentage of on and off times is not working properly.
    the part you need is #12002125 you can get it online or locally for about 30 bucks.
    to replace it, first shut off the breaker to be sure you dont have any power going to the unit. then remove the cook top from your countertop. remove all knobs,then take off the screws that hold the glass top to the metal bottom frame. then with the glass off you can get to the 2 screws that hold the switch in place. make sure you have the new switch with you as the wires need to be put back in the exact same place or you could short out the new switch. might even be good to take a close up picture of the old switch and wire colors so you dont get it wrong.
    hope this helps you to get it fixed and if you have any more questions, just reply back to me with an email.
    thanks tom
    President:
  • 1,952 Answers
You can use the cooktop wire for the new vent fan.
  • 163 Answers
Hii you need to chance your infinite switch which turns it on and off..
  • 142 Answers
Though im not completely familiar with appliances, but If i were to have this happen to me, I would contact the manufacturer for troubleshooting help from a live person, or for a repair.
Posted on Dec 31, 2008
The left top element is not working, the control knob lights up but doesn't heat. Is it the element or the switch? Mod#JED8430BDB Ser#1414040011A Schott Ceran
It could be either. The only way to properly check is by dismantling the cooktop and checking the circuit with a volt meter or test lamps.
Feb 11, 2011 | Jenn-Air JED8430 Electric Cooktop
Glass top cracked. What is replacement part number
check out
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47639&diagram_id=681565#d681565
Oct 26, 2009 | Jenn-Air JED8430 Electric Cooktop
Stove top will not heat oil hot enough to fry foods. Burner continues to re-cycle on and off while switch is on high. Burner gets red hot for a few seconds then turns off for a few seconds, then back on.
You may have a cracked element, they expand when heated and cause a separation in the element. You really have to put a voltmeter on it to test it under load. If the voltage remains constant while the element is heating and cooling, then indeed you have a bad element.
If you don't have a voltmeter, or don't want to perform this test, buy a heating element and replace it, if you have the same problem, you'll have a spare element
May 14, 2009 | Jenn-Air JED8430 Electric Cooktop
GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Mar 02, 2009 | GE Cooktops
Did the element fail, or the switch, or the harness?
Buying and learning to use an ohmmeter is best. You can also inspect both the harness and the burner for damage. If nothing is burnt or broken, then you probably need the switch. Hope this helps!
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Tripping breaker
Replace the burner and receptacle and you should be short free. You may also need to replace the surface element switch too if it doesn't come on at all or stays on high regardless off knob setting.
Dec 16, 2008 | Jenn-Air JED8430 Electric Cooktop
Dual Element
check underneath the element, you may have something preventing the element from gihting up. if you didn't find anything, then it is time to get a new element.
Oct 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Heating element will not come on
The best to test that is to remove the top and take the outer coil and use it on any of the other burners to see if it heats up, then youll know for sure is the element or the switch.
Eddie Rentas
Tupper Lake NY
May 14, 2008 | Jenn-Air JED8430 Electric Cooktop
Knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
249 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
