Question about Panasonic PV-DF2004 20 in. TV/VCR/DVD Combo
DVD player The DVD player doesn't work. When a DVD is inserted, the player makes noise as if loading the disc and the screen says "reading", but then stops, and seems to try again. This happens 4 times before stating "this type of disc cannot be played. please insert a different disc". I have tried countless DVD's, all of which work on any other DVD player, but do not work on this player. (and no, the DVD's aren't burned, theyre store bought).
  • 4 more comments
  • Chris Clarke May 05, 2007
    uhh...huh?
  • mpmpmpmp Mar 24, 2008
    have 2 of these units. neither dvd works. both worked for a short time. now both have the same error you get. I think it is a manufacturers defect.
  • Anonymous Mar 29, 2008
    dvd's are not being read. flashes on screen that dvd is not appropiate type?
  • Anonymous Jul 27, 2008
    vcr and dvd combo will not play a disc . i have tried many disc and all i get is on screen is wrong disc insert a correct disc
  • Anonymous Aug 03, 2008
    Unfortunately, I have the same exact problem. Tried w different lens cleaning disks which did no good.
  • perryted2 Dec 24, 2008
    says needs another disc and won't play dvd
What ???
Posted on Dec 22, 2007
I have the same problem with my home unit, I have access to another at work that works fine. I tore apart my home unit (being experienced in electronics) and tore the dvd player out to examine. I could not access the lens to clean, and had no power source to bench check unit. I am now wondering if the unit is even spinning up and checking this is my next step.
Posted on Aug 04, 2007
    Problem Solver:
  • 8 Answers
Try to clean dvd's and dvd player les
Posted on May 04, 2007
Its posibal your dvd not rogins the informations is tiping of dvd
  • 4 Answers
Follow-up to Aug 04 response: I spent a few hours today tearing mine apart (3 times, once for a **** mistake of not reconnecting all wires). I verified unit spins with a dvd, checking the position when open/closing. Tore off back case and retore dvd player out of unit, took time to fully take off case and gently clean laser lens, reconnecting dvd to frame, and checking it out with several discs (TIP: If you do this, tape open the vcr door so it will catch when you put on the cover, otherwise will not open auto when ejecting). I now believe the problem is at the component level or laser is out of alignment, both mean it is not efficient to repair. Also, I just saw on e-bay SEVERAL units of the same model being sold for .99-$49.99 because of the dvd not working. I may try contacting Panasonic and try to purchase the whole dvd unit to replace if reasonably priced.
Posted on Aug 06, 2007
Drc99391
Usually if "no disc" the optical unit in the player is either dirty or bad.
If bad cheaper to buy a new unit as individual parts are not usually sold for this type of equipment.
Dec 08, 2012 | RCA Televison & Video
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
I have a Samsung DVD-R155. When I insert a DVD, the screen reads "load", but eventually it screen will say it can't read the DVD, and then ejects the DVD. It doesn' t matter if it is a new or used DVD. I...
Try using a DVD scanner eye cleaner. It is aDVD with a brush grafted to it. I suspect the scanner eye is dirty so it cannot read the boot starp properly and so ejects
Aug 15, 2009 | Samsung DVD-R155
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Some DVD players requires installation of software to load some DVD's. Ask your dealer to provide you with a Software CD. Just insert this software CD and then try to run DVD it will work...
Oct 04, 2008 | Samsung DVD-R155
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
At loadup.
check your disc's that it's not putting a mark on them...
sounds like the laser is hitting the disk trying to get it to focus,
thus it's either the spindal is to low or not moving or the laser is week or not in the correct position
Dec 04, 2007 | Apex Digital AD-1125 DVD Player
Magnavox 26MD255V/17 dvd player
buy an external DVD player, save yourself time, money and frustration.
Nov 13, 2007 | Philips 26MD255V 26 in. LCD TV/DVD Combo
My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Mar 20, 2006 | Panasonic DVD-S31S DVD Player
Panasonic PV-DF2004 20 in. TV/VCR/DVD Combo Logo
265 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
