Question about Crown XS900 2-Channel Amplifier
Crown amp xs900 will not reset
My crown amp xs900 shut down and wont turn on , I tried to press the reset buton but it would not work please help me....  naz
  • Guildman Feb 22, 2009
    I hooked up my Crown Xs1200 and switched on as normal. Made a loud Low frequency rumble and immediatly shut off and went into "fault." now when you turn it on it comes on, channel 2 clip light comes on for about 2 seconds then it shuts down and the "fault" light come on. And this is with NOTHING hooked up. no input, no output. only power cord. I've had other amps do this, but would never expect it from Crown. anyone know what i may be doing to cause this power amp failure?? Thanks
  • sloppy macho Mar 13, 2009
    I have had this very same problem with this amp. I purchased it brand new a few years back, never had anything go wrong now, forget it I've had it looked at once already and thought the problem was fixed then the problem came back again, but now worse. The AC mains light stays on and won't shut itself off and on top of that , I used it for my Bass set up w/ BBE preamp and got no power at all now. What is this problem thats happening?
    Problem Solver:
  • 6 Answers
naz, get a hold of crown, tell them whats up. check all fuses and connections first. the unit is worth $900.00. they should be a little understanding.
Features
  • 2-ohm dual (per channel) : 1200W
  • 4-ohm dual (per channel) : 900W
  • 8-ohm dual (per channel) : 600W
  • 4-ohm Bridge : 2500W
  • 8-ohm Bridge 2100W
  • Indicators for : Signal, Clip, Power, AC Mains, Fault, Bridge, Temp.
  • Housed in a rugged, all-steel 2U chassis
  • Microprocessor-controlled protection system.
  • Flow-through ventilation from front to back.
  • Internal heat sinks with forced-air cooling for rapid, uniform heat dissipation.
  • EIA Standard 19-inch rack mount width
  • Safe with all types of loads.(2 to 8 ohms in Stereo, 4 to 8 ohms in Bridge Mono.)
Inputs
  • XLR-¼" combo connectors: One per channel
  • 3-pin female XLR connector and TRS ¼" phone jack accept balanced or unbalanced signals.
  • 3-pin Phoenix-style connectors (2-channel models only),One per channel, accepts balanced or unbalanced signals.
Output
  • Balanced XLR connectors (2-channel models only)
  • One per channel, 3-pin male XLR connector in parallel with XLR-¼" combo and Phoenix-style input connectors for daisy-chain operation.
  • 5-Way binding post output connectors: One pair per channel; accept banana plugs, spade lugs or bare wire.
  • 4-Pole Speakon output connector (2-channel models only)
  • Accepts a 4-pole Speakon connector.
Posted on Jan 01, 2009
I just bought a police kickers timepieces watch i dont know how to set the day i've tried hundreds of time but its not working can some one help me !!
Since you have stated ABSOLUTELY nothing about provinance... model, year... owners manual POLICE being a pretty decent watch from the UK (I'm going to skip right on past the AUTHENTIC notion... Chronograph (shown).
If your your watch is a REGULAR knock-off (replicant)... t has the miyota movement...
A highly precise and reliable motor
in it's own right.
(sets very much like the high end valjoux cousins)
It is a crown-set... typically a three position stem set.
Force nothing... !!
Some GENTLY unscrew the crown... others will pull out
to set: 1, TIMW 2, DATE... THREE (back to normal -closed).
In the closed position
The stop/start butons do precisely that on those SUB-DIALS.
In the SET positions the start/reset buttons are used to ZERO those sub-dials (press & hold... then individual clicks will move each hand to zero).
Hope this helps!
http://www.bing.com/search?q=watch%20valjoux%20quartz%20movement&qs=n&form=QBRE&pq=watch%20valjoux&sc=0-13&sp=-1&sk=&cvid=607E5483C971481BBCFF824956E6A0D7
police quartz movement Bing images
Jun 25, 2016 | Police Watches
Is there an online instruction manual for Kenneth Cole Model KS3025?
i don't know about on line instruction.
but i could help you ....
there is two position for crown 1 and 2.
bring crown on position 2 and turn crown clockwise to change TIME, DAY & DATE.
bring crown position 1, and turn crown counterclockwise to change DATE.
your watch has Chronograph / Stop watch.
use that please press right TOP button chronograph will START, press again Chronograph will STOP.
Press bottom button to RESET Chronograph.
hope it will help 9k=
Jun 06, 2014 | Kenneth Cole Watches
Why will my canon pixma mp250 not reset a refilled color cartridge
i dont think you where trying the right solutions. the mp250 catridge 511 can not be reset as far as i know. what you can do to get it to print is to long press the reset button. this disables the ink level check function and you can work. the procedure you stated is usually for resetting the ink absorber, not catridges.
Good Luck!
Jan 16, 2013 | Canon Pixma MP250 All-in-One Color InkJet...
Sanyo S770 lens won't retract on shut off and shuts down when try to zoom and get lens error
Lens error happens during the lens guide pin wrong movement. Please try these below and let me know.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 06, 2011 | Sanyo Xacti VPC-S770 Digital Camera
Wont shut down or start up zoom lense gets stuck open
Hi there please follow the steps and let me know the result.
Jan 22, 2011 | Ricoh Caplio R6 Digital Camera
I'm tying to copy, comes up with check ink u163 col
It seems as though the ink counters are not being reset. Please follow the instructions below to reset your printer. Please read and follow the directions carefully as skipping any steps will not correctly reset your printer.
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Re-install the printer cartridges and give it a try.
Aug 15, 2010 | Canon PIXMA MX310 All-In-One Printer
Reset chronograph minute and hour hands to zero
pul crown all they way out
press top right button to set the minute hand
& bottom right button to set the hour
if not work then puch back crown to 1st click and do it same function ,, if still not working then pull crown again and push and hold both button for 5 sec. its reset ,, and try to adjust it again by pressing top & bottom button
hope that will help if not and you are in chicago
bring it to us
at
Amfix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
312 641 7000
Aug 27, 2009 | Pulsar 100 Meter Alarm Chronograph PF3277
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
I plugged in my usb for my hp wirless optical moblie mouse and for some reason the light on the usb wont blink it just stays on I even press both the buton on the usb and the mouse that sais connect and it...
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Nov 12, 2008 | HP Wireless Optical Mouse
Help front panel wont work and treble +10 keeps coming up by itself
Check all of the push buttons on the front panel.. I have seen that sometimes a switch could have gotten jammed or pushed an and broken and the button gets stuck and wont let anything else work
Sep 21, 2006 | Yamaha HTR-5650 Receiver
Crown XS900 2-Channel Amplifier Logo
605 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
