Question about KitchenAid KSM5PS Heavy Duty Stand Mixer
I have a KSM5PSER stand mixer. What attachments will work with this model?
I'm referring to the newer attachments like the juicer, shredder, noodle maker, etc.
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: blade won't release from mixer
To Remove Flat Beater, Wire Whip or Dough Hook
1.
Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft.
If the beaters are stored on the shaft of the mixer when not in use, food traces can harden and make mixer attachments difficult to remove. Should this occur, wrap a hot, damp towel around the shaft to heat and expand the area. A small amount of cooking oil sprayed around the shaft may also help. After the beater has been removed, thoroughly clean the beater shaft area with a small brush to remove any food residue.
-Tha Mp3 Doctor
Posted on Dec 30, 2008
ricardok45
  • 135 Answers
SOURCE: Model KSM90 10 speed ultra power stand mixer
Hi. Your mixer needs to be serviced, have old grease and oil removed, parts cleaned, then re assembled with new grease. Remove the tapered-pin from the planetary gear, remove planetary gear, clean lubricate and re install. Chevron FM ALC EP-2 is a "Food Grade" lubricant, meaning that it's safe for human consumption if it accidentally gets into food. There are no seals, only bushings. The existing bushings will hold back the new grease. The oil has separated from the base of the grease. If you don't use your mixer very often, start it up about once a week to keep the grease properly mixed.
If you'd like more info on your mixer goto kitchenaid.com, look up your model # download the PARTS drawings. Use these drawings to re-assemble and to determine if you need any replacement parts. Be prepared to wait at least a month for your parts to arrive.
If this Solution assisted you, please rate it. ricardok45
Posted on Mar 14, 2009
ricardok45
  • 135 Answers
SOURCE: KitchenAid KSM5PSGR Stand Mixer - attachments not turning
Hi Gail. Kitchenaid no longer has a Parts List for your model. This means that they consider it obsolete. Do an Internet search for parts. You may get lucky. Good luck!
If this solution has assisted you, please rate it. ricardok45
Posted on Apr 04, 2009
SOURCE: I recently acquired a KitchenAid/Hobart Model 4C
A number of attachments were available for the 4C, such as a juicer, a meat grinder, etc., all of which ran off the PTO on the front of the housing.  The only beater, however, was the wire one.  No dough hook was ever made.  I have been told that the motor didn't have the necessary power to run a dough hook.
Posted on Oct 02, 2009
  • 53 Answers
SOURCE: How do you use the KitchenAid SNFGA Pasta Maker Attachment
If it's gumming up, the dough is too wet and needs to be dried out more by adding flour. The right consistency dough is such that if you tear off a small piece and then tear it in half and squeeze it back together with your fingers it should stick back together but not stay stuck to your fingers. If it stays stuck to your fingers it's too wet and needs more flour. If it is crumbly, it's too dry and needs more water.
Posted on May 31, 2010
How do I install the shredder?
You need to access the accessory attachment point, it's behind the silver KitchenAid logo on the front of the mixer. You'll need to unscrew a set screw (black knob at the very front of the mixer head), newer mixers have a hinged cover, on older mixers, it just pulls out. Unscrew the set screw a bit and fold up or remove the cover.
Now you will see a hole with a hollow square shaft inside, this is where the various optional items attach to the mixer.
Specifically for the shredder, you will need to attach a slicing drum to the drive shaft provided with the shredder, insert it through the drum, and raise the little bar in the rear of the slicer assembly.
Insert the whole assembly into the front of the mixer so that the square drive shaft shaft fits into the square hollow in the mixer, then lower the little bar to lock into place.
Dec 31, 2015 | KitchenAid kitchen aid"" classic stand"
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
We the multi-functional mixer attachments but now unable to get shredder to attach correctly
Remove the shaft an cutter first and install the outside case of the shredder. Tighten thumb screw. You may have to lift up on a lever that runs in a groove in the shaft to remove the shaft.
Next install the shaft with cutter attached. Lube the shaft with tiny bit of mineral oil or food safe grease. Lift the lever mentioned above and rotate till the shaft seats and then drop the lever and make sure it is engaged.
Feb 03, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
I recently acquired a KitchenAid/Hobart Model 4C stand mixer for free. It seems to work okay but I?m in need of a flat beater, dough hook and wire whip as it came with only the juicer attachment. Do you...
Jul 25, 2009 | KitchenAid Food Mixers
Clicking noice in gears
A clicking noise is not indicative of a major motor issue with a Kitchenaid stand mixer. If the noise worsens or is accompanied with other symptoms, or if you are incredibly concerned with the development of clicking, I would suggest contacting Kitchenaid Customer Service.
Their toll-free telephone number is 1-800-541-6390.
Apr 04, 2009 | KitchenAid KP2671 Professional 6 Series...
Are attachments for a KitchenAid K5 compatible with the K55?
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
Apr 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
I bought the slicer and shredder set for the KitchenAid stand mixer, no instructions were in the box. What speed do I use the attachments on?
Your attachment speed will depend on what it is you're slicing or shredding. Begin at speed setting two and work up to the speed where the motor begins to labour, then reduce the speed by one notch. Always start too slow, then move up. If you find this solution usefull, please rate it. Good luck. ricardok45
Dec 05, 2008 | Hobart A200 Stand Mixer
Citrus juicer
Hi.
maybe you need the nut (adaptor and washer ) for attach your juicer ...
you can get in www.4kenwood.co.uk
regards
kenwoodchefrestore.co.uk
Jul 24, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
133 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
